Old 07-16-2022, 08:02 AM   #1
mielmonteur
Drives: Yaris P1 1.3 3 door 2003
Apex dampers opinions?
Hi,
I got a set of Tein S tech lowering springs still with the original dampers. These are still in quite good condition since the car has not even done 90k kms (new in Toyota terms ;)
Now I am looking for some dampers to go with these springs. It is for street use, since going to a track is quite expensive... Don't daily it but don't want to shake my behind off aswell...
Now the Koni orange/yellow's are very available here in the Netherlands. These are quite expensive (student life). I have found a set of Apex dampers for the price of 1 koni shock, 125 euros. Is this worth a shot or just go with a koni set for 400-700 euros? Couldn't find anything on these so does anyone have any experience with these Apex dampers?
Thanks
Edit: part numbers for the apex shocks 7101410 and 7102110
mielmonteur is offline   Reply With Quote
Old 07-20-2022, 12:14 PM   #2
mannycheckers
Drives: 2009 Yaris 2dr Liftback
I'm not familiar with the first gen Yaris. We only had the "Echo" in the states.
With that said, newer dampers are generally better than old ones. But, you also get what you pay for. So cheap dampers may not be that good.
I would either go with the Koni's, see if Toyota has TRD dampers, or see if Bilstein B8 Performance dampers fit on your vehicle.
If these options are too expensive, you could look into KYB Excel G as they should be the same as OEM.
I don't know if I would get the Apex dampers.
mannycheckers is offline   Reply With Quote
Old 07-20-2022, 01:55 PM   #3
sh0rtlife
hate to be that guy..but the truth on dampers is that only a handfull of companys ACTUALY make them
koni, bilstein, kyb, gabriel, monroe and a couple others
toyota useualy uses kyb (made for them by kyb) with a few exceptions, id be suprised if apex didnt use gabriel or monroe..which..is both cheep and not that great
for alot of owners tho "cheep" dampers are just fine for how they drive...
Old 07-23-2022, 06:52 AM   #4
mielmonteur
Allright, thank you. I will just save up a bit and go with the koni str.t. First going for the whiteline arb.
apex, dampers, koni, shocks, tein s-techs
air intake opinions? scoobopdan Performance Modifications 19 10-04-2014 02:31 AM
Shortest springs with original dampers; Yaris 3dr 2009-2011 Ot_tO Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 02-13-2013 08:12 AM
I NEED Boost... Opinions puh-lease Focus_Sh1ft Forced Induction Forum 551 02-08-2013 06:55 PM
rim/coilover opinions ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-12-2010 08:02 PM
