![]() Drives: none yet Join Date: May 2010
manual vs. automatic
If there is already a thread about this secifically, can someone point me to it? I looked, but couldn't find one.
From browsing the threads, it seems like peole with manual transmission get really good gas mileage, but I've seen some reports with the automatic that aren't as good. I'm trying to figure out if this is a coincidence based on what I've seen. Can people post whether they have a manual or automatic and their average mpg? Or if anyone knows real-world mpg manual/auto comparison reports, that would be great. I ask because I was planning on getting a manual, but I'm looking at a specific automatic one, now, and I want to make sure I'll get the max gas mileage because that's one of the main reasons I want the car. Thanks! |
Half a Bubble Off Plumb
There are several threads on it. Manual drivers tend to do a little better, as the published mileage estimates suggest. I have an automatic and usually average from 35-38 MPG, nearly all driving around town. You can't get a very valid comparison from drivers' posted reports, as driving skills, traffic conditions and terrain vary widely.
Modded Moderator
I average about 32 or so in town with my auto, vs. 38+ with the manual my gf has. Honestly if you want max fuel go with the manual. Mine is super modded though, the gf's is stock (for now).
With the help of SGII
Drives: 2009 Yaris Sedan Manual Join Date: May 2010
I have a manual, i drive about half city and half highway and i have a scangauge II. I usually average low to mid 40's but on the highway i have gotten as high as 55mpg with careful driving.
I'd get the manual if you enjoy driving,
if you are regularly stuck in rush hour traffic then go for the nanny tranny. |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
I have the auto and drive mixed city/rural mostly and my lifetime fuel economy is 41.7 mpg. I try to drive for good economy and use an ecometer.
I love the auto personally, but if fuel economy is your main concern I would choose the manual unless you have another compelling reason to go with the auto. R2 |
i got 31mpg all-city last tank. i have and manual transmission, intake, header, and a resonator-back exhaust. also on 205-45-16 tires and 16x6.5 wheels. my commute is about 7miles into work. i think thats still pretty decent.
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
I think it depends on what type of driving you do. I think we have a clutched torque converter so once it locks up they both should use the same amount of fuel.
I’m getting around 43mph if I stay on the highway and about 35 on back roads.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Stick shifts are great. You can control your shifts...
If you live in a Northern climate you may want to buy the 5-speed manual. In snowy weather you can gear accordingly to the percipitation levels. On very slick/snowy roads... from a stand you can start on the 2nd gear and gain traction with the lower torque. Not recommended to do this all the time... clutch will go-out sooner. You also can jump start when the battery is dead... depending on your environment. No need for cable jump! ![]() I'm averaging on my manual tranny around 46 MPG. Work round trip is around 40 miles. High average is because of several road (Interstate) trips using the mountain terrain for long glides. Good luck on your purchase decision...
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I average in the low to mid 40's with the manual. If you drive a lot of hills or dread the idea of rolling back a little and even stalling it, then go with the automatic. I've driven manuals from the get go growing up on a farm, but I stall the Yaris on hills if I have to stop on one. I've learned how to use the parking brake to hold the car till it starts to go, but there is a delay from when I step on the accelerator pedal and it actually goes. Love the electronic throttle-not. But love the fuel mileage and the delay is nice in the snowy months-it helps keep traction even though the car does not have ABS or traction control.
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
You can control your shifting, have another gear which should help to keep your RPMs lower, exploit DFCO easier, compression brake and even coast in neutral a lot easier with the manual.
I get 45+ mpg to the tank at about 30/70 city/highway these days. I agree on starting in 2nd, it helps a lot on starts in the snow. To me the only advantage to the auto is driving in heavy traffic, but I just adjust my speed enough to try to eliminate or at least smooth out the stop and go, which is better on gas mileage, brakes and transmission anyway ... but it's a skill that I've pretty much had to master on the motorcycle. |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I have the manual and routinely get 40 - 45Mpg on my commute, with an all time high of 54Mpg on 2 FE runs in the summer.
However, getting a ScanGauge II and adjusting my tires are the 2 things that got me the most increase in Mpg. When the car was new, I was only getting the EPA rating of 36, with an occasional higher tank average. Now I track it by the trip with the ScanGauge and have to drive pretty sloppy to get below 40. Note that only once a month or so do I have more than 15 minutes of real stop and go city driving on my trips. Some people coming from larger vehicles have trouble adjusting to the Yaris clutch. But for the driving I do, the slightly better FE and more enjoyable performance makes it well worth while to have the manual transmission. |
Audio Junky
Manual 3door
Average for the life of the car is just over 40mpg. Average for the past 90 days is just over 39mpg. I drive mostly in the 35-45mph range, with as little highway driving during the week as possible. I do have around a dozen 1,000 mile trips @ 75mph under my belt which usually net around 35-37mpg tanks which significantly lowers my average. |
I have an auto with bigger tires, and still get 35 MPG out of it. I still shift a lot, and enjoy driving it as much as a manual; but the nicest thing is that you can let the transmission do all the work if you so desire. As I always say, you can always shift an auto but there is no way you can ever get a manual to shift for you!
However, manuals do tend to get slightly better gas mileage. It's just that you have to do so much more work when driving, something I like to term "manual labor" ; whereas with the auto driving is so much more refined and civilized...Cheers! M2
#15 | |
"LibertyRides!"
![]() If I may ask? What pressure did you set your tires? I just set mine to 38psi. Presently, I don't have ScanGuage II. I just listen to my engine... look at my tach all the time, and shift very gingerly. Mind you, I drive like a grandma. ![]() I hear SG II helps out! Have you heard of Ecometer? I'm looking at Ecometer... the cost! I really don't know what either product offers... ![]() Cheers!
The torque converters do have a clutch that locks up. But the auto is a 4 speed, and the gear ratios are a little different.
#17 | |
My all time high was on a 19 mile highway trip from portland or to hillsboro or. I netted myself 55.5mpg on that trip, have yet to beat it. lol I havent heard much about the ecometer, but i would definitely suggest the scangauge for anyone looking for mpg's. |
#18 | |
"LibertyRides!"
You mentioned $14,000 for an automatic that a dealer will sell to you in the other Thread? This seems about the going sale price, but I believe you can do better! Try to get it for $13,860 or under. If dealer asks for > $14,266... it is 'Over Priced'. Also, take in consideration 'dealer holdbacks'! This is why you can get it below $14,000. Note this is with the Convenience Package and my region (zip code).... it might be lower or higher in your locale... Cheers!
| Tags |
| automatic, manual, mpg |
| Automatic to Manual converts... any regrets?? | maramaralula | New YARIS Purchase Forum | 22 | 07-31-2011 10:06 AM |
| Is LSD Automatic & Manual Same? | maxgil05 | Performance Modifications | 4 | 04-24-2009 10:57 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Change automatic to Manual | Blenjar | General Yaris / Vitz Discussion | 11 | 06-14-2007 06:02 AM |
| Manual vs. Automatic ?? | YarisBlazer | General Yaris / Vitz Discussion | 12 | 08-13-2006 07:14 PM |
