Old 05-12-2017, 08:11 PM   #1
toad
toad's Avatar
Drives: street-legal go-kart
Echo, xa, xb shocks interchangeable?
Did a little searching and found most posts dedicated to Echo/Yaris swaps. What I'm wondering is if older xa, xb(first gen) shocks will fit my 2001 Echo? I'm finding some pretty good deals on xa, xb shocks, but I think I've read somewhere(probably here) that they will fit- just not set for the proper weights.
If so, is there that much of a difference in weight between the three to make a difference? The fronts I'm ok on, I'm just concerned with the rear shocks for now. I'm keeping the factory springs also. Thanks!
toad is offline   Reply With Quote
Old 05-12-2017, 10:40 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
old compatibility page:
http://www.toyotanation.com/forum/26...xa-xb-etc.html
Old 05-13-2017, 08:38 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I heard xB front struts will make the car sit higher. I'd go with xA front struts.
Old 05-13-2017, 09:39 PM   #4
toad
toad's Avatar
Originally Posted by enviri View Post
thanks for the link! i often just think of yarisworld when searching. the page on toyotanation keeps mentioning struts. is that just generic for dampers in general or are they referring to actual struts? the xa fronts i've already decided on, now i'm just trying to figure-out what will fit in the back(shocks) without making it sit even higher than it already is. i'm going to stick with stock springs for now- i just want something to keep the car from bouncing on major dips.
thanks again!
Any rear shocks out there interchangeable with Yaris? DeathBeard Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 07-04-2013 03:58 PM
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech over Stock shocks daddz07 General Yaris / Vitz Discussion 0 08-10-2010 10:48 AM
front shocks independent from rear shocks? ammophobia Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-04-2010 11:34 PM
Previous gen Echo shocks on current gen Yaris kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 02-28-2009 12:47 AM
