Old 02-19-2011, 07:48 AM   #1
henrystyle
Drives: 2010 5 door yaris
Removing a yaris grill
I bought a trd grill emblem for my car. Went to put it on noticed that the yaris is tight as hell under the hood. Can anyone share some info on how to pop out the grill so that I can put on the emblem? I see I wont be doing to much of the mods on my car myself. I can take apart stuff but putting back together is another story when it comes to cars. Lol
I want to add a air intake, exhaust, and rear sway bar. 2010 5door liftback.
henrystyle is offline   Reply With Quote
Old 02-19-2011, 08:05 AM   #2
henrystyle
Also fog lights and the rear spoiler..
Old 02-19-2011, 10:57 AM   #3
sex
sex's Avatar
Drives: 09 5DR
get manuals from http://www.etimago.com/yaris/repairmanual/
see page ET-66 (exterior)
sex is offline   Reply With Quote
Old 02-19-2011, 01:57 PM   #4
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
My grille was really hard to remove and I had to take off the front bumper....this is super easy...
under the car up front are 3 screws...10mm take them out.
under hood on the bumper are some pop out pins,black plastic....pop them out.
in each wheel well up front is another pop pin...take that out.
seems if I remember there is also a 10mm screw under the fender liner behind the pin in wheel well,but that may of been on my tC.
then take the bumper at the side where it meets the fender and give it a tug and it comes loose from the fender,then you do other side and the bumper can at that point be mostly pulled right off.
Shold take like 30 min first time,after that it takes like 5 min to do lol.
Popping out the grille it is easier with a friend to keep the tabs pushed out and grille moving out the bumper...you will see...took me longer to get the grille out than the bumper off...
Old 02-19-2011, 02:04 PM   #5
big lo
big lo's Avatar
Drives: 2007 VIOS
^+1
Old 04-08-2017, 02:09 PM   #6
A-Jey
Drives: 2008 yaris sedan
Same here, i bought an RS emblem. I'm going to attempt to just take off the plastic belly pan see if i can get at it that way.
A-Jey is offline   Reply With Quote
Old 04-09-2017, 12:51 AM   #7
A-Jey
Finished installing the grill emblem. You don't have to take off the bumper, just remove the belly pan & you can reach to Install it. For the emblem buy nuts with nylon inserts so they stay locked on. You can also trim the bolts to the emblem they are very long, I trimmed mine with a grinder. Grill emblems give the Yaris a nice look.
Old 04-09-2017, 01:28 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
That worked for me on my 07. Really tight though... and some seriously scraped knuckles!
No place to install the RS emblem on the grille of the 14, but I did put one on the hatch.
Old 04-09-2017, 09:23 AM   #9
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
Anybody have luck removing a 2015-2016 bumper? I'm guessing it's similar but was looking for a heads up before I start. Thanks.
Captain Yaris is offline   Reply With Quote
DIY - Adding Front Lower Grill Mesh 33OH Cosmetic Modifications (Exterior/Interior) 24 08-13-2013 04:06 PM
Opinion on front grill IllusionX Cosmetic Modifications (Exterior/Interior) 20 04-22-2009 09:53 PM
Sedan Grill Options tuckevalastin Cosmetic Modifications (Exterior/Interior) 15 12-29-2008 11:59 PM
Need help, removing grill, adding new one drbilal DIY / Maintenance / Service 4 10-29-2008 10:11 PM
DIY: Yaris Hatch grill block/air dam yarswiss DIY / Maintenance / Service 0 10-26-2008 07:52 PM
