![]() Drives: Yaris MK1 Join Date: May 2021
Oil dipstick very hard to remove and insert.
Hey guys, I have just bought a Yaris 2003 with the 1.3 VVTi engine with 195.000km's or 121.000 miles and I'm pretty satisfied so far!
However soon after I bought it I went to check the oil (should've done it before buying, but it's a Toyota so what the hell eh?) and I found the dipstick was loose in the dipstick tube. So I pulled it out, cleaned it and went back to insert it but it would not go in at all. So I pushed on it a bit more and it finally went inside, however the amount of force used to push it in and take it out do not seem normal to me. Luckily a co-worker of mine has the same car and his dipstick is very easy to take out and re-insert. I've compared the dipsticks and they look identical, both yellow plastic all the way. Has anyone else had this problem, and if so how did you remedy it? Thanks in advance! |
If there is an O-ring on it that might be the problem. There also might be buildup on the inside of the dipstick tube. My daughter recently bought a RAV4 and never check the oil. You need to lube the dipstick Oh ring
Oldie
Drives: 2012 yaris sedan Join Date: Apr 2021
Or......its the wrong dipstick.
Hey there, there is an o-ring on it. As it seems it should have.
Like I mentioned my co-worker has the exact same engine and the dipsticks are both identical to each other including o-ring. Build-up in the dipstick tube is a possibility I have not looked into yet as the weather has not allowed me to due to loads of rain. I'll check it out in a couple days, maybe clean out the tube if it's dirty and I'll report back! |
In the meantime I would put oil on the O-ring and see if that helps. Bhyou need several applications.
If you remove the O ring, does it get better? Definitely not advisable to drive it like that but if the clean-up and oil-up does not help you may need to replace the O ring. Some people tend to add various shits to the engine oil and it may have caused the O ring to swell. Just guessing.
You can also try to swap the dipsticks with your co-worker to identify whether the problem is the dipstick or the engine. |
| VVT Oil Control Valve Filter Replacement (the other oil filter) | 2bz | DIY / Maintenance / Service | 7 | 08-02-2024 02:44 AM |
| DIY - How to remove or insert a pin on the ECM Connector A21 | CTScott | DIY / Maintenance / Service | 6 | 05-21-2024 12:29 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Shift Knob Threaded Insert Install DIY | Yariz_Hatch | DIY / Maintenance / Service | 1 | 02-09-2012 08:15 PM |
