![]() ![]() Drives: 2017 Yaris SE Blue Streak Join Date: Aug 2017
Brake pedal travel
I just noticed today that the brake only moves probably 3 to 4 inches, is this normal? I tried lifting the pedal and there is no movement backwards.
And if the battery is disconnected do I need to do anything related to the abs module or is it ready to go once battery has been connected Sent from my SM-G930W8 using Tapatalk |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Brake pedal travel souds about right. Youre good to go with the abs.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
Thanks.
Just never paid attention to it Sent from my SM-G930W8 using Tapatalk |
| Hiss or pfft when pressing brake pedal | kwk442 | DIY / Maintenance / Service | 3 | 06-03-2017 06:10 AM |
| Brake pedal goes stiff under heavy braking, no ABS engagement? | CrankyOldMan | Tracking, Racing, Auto-X Forum | 6 | 05-26-2015 09:09 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Brake pedal vibrates-not rotor problem | rradhay | DIY / Maintenance / Service | 9 | 11-12-2010 09:10 AM |
