Old 03-03-2009, 02:40 AM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Throttle lag and response
I bought a PLX Kiwi. I've been using it in sensor mode. I discovered tonight that there is a throttle lag and it does not open beyond 81%. No matter how much I floor it it won't go beyond 81%. On acceleration it will pause, go to 50%, pause and then 70%, then to 80%. On passing there is that same pause. I would like to say half a second to a second, but I'm guessing.
I know it's DBW (drive by wire), but this is a big lag. Also, it doesn't open beyond 81%. This can only mean that DBW is preventing full performance of the engine. Do you think this is true?
Old 03-03-2009, 03:26 AM   #2
ddongbap
Is this true untill redline?
Old 03-04-2009, 02:53 AM   #3
yaris-me
Learn to Relax
Tonight I tried some more. I have an AT. When the water temp reach 172, I started to floor the gas. First to second it shifted at 5400 and later at 5800. Second to third shifted at 5800 and later at 6000. Third to fourth shifted at 5800 and later at 6000. After a while, the highest shift point was 6100, third to fourth. The ECU never allowed me to redline the engine and the throttle never went beyond 81%
The throttle lag is gone. I think the ECU is adaptive and after a while it eliminated the lag.
Old 03-03-2009, 03:34 AM   #4
yaris-me
Learn to Relax
I couldn't take it to redline, but first to third it shifted on its own at full throttle. I was on Broadway and later on Magnolia. I'll play with it some more tomorrow.
Old 03-03-2009, 03:35 AM   #5
ddongbap
Yea, I don't think its normal. If 81% was normal, you'd still hit redline, you know what I mean?
Old 03-03-2009, 03:47 AM   #6
yaris-me
Learn to Relax
I didn't have enough road to really open up the throttle. I'll have to try again on the freeway.
My initial feeling was that the DBW and engine management computer is preventing me from damaging the engine. If this is true then being able to reprogram the computer would allow you to gain more HP and better performance.
Old 03-03-2009, 05:45 AM   #7
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
Would the Blitz throttle controller help with the 81% throttle issue? or does it just open the throttle faster getting to the 81% limit SOONER? It seems like it would help with the lag with the DBW though.
Old 03-03-2009, 08:18 AM   #8
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
I noticed the same thing on my car. I've heard of the same issue on other DBW cars as well.
Old 03-03-2009, 06:12 PM   #9
The Blitz unit changes the curve but not the top limit, I think.
I've heard this post before about it not opening up past 81% -- curious.
Old 03-04-2009, 10:07 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
in an automatic, i belive the ECU is able to detect your load and shift accordingly to that.
try to sit 4 in the car and do the same test again. i'm 99% sure it will shift closer to redline. At least, this is what i noticed with my 93 swift. Alone in the car, I always wondered why it would always shift at ~4000-4500rpm until one day we were 4 in the car and going on an incline... it went all the way to redline before shifting..
Old 03-04-2009, 10:18 AM   #11
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
ANy ideas on a manual?
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 03-04-2009, 01:43 PM   #12
yaris-me
Learn to Relax
I think the ECU determines maximum engine output. The ECU would probably limit fuel after 6000 RPM preventing you from damaging the engine. I think this would apply to manual also.
Old 03-05-2009, 05:10 PM   #13
IllusionX
the redline is somewehre around 6250rpm.
i got to the cutoff a few times.. it's around 6500rpm. i would love to have a scangauge to know the real answer to this...
Old 03-05-2009, 07:28 PM   #14
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Scangauge reads the same max throttle 80%
Old 03-05-2009, 07:50 PM   #15
blktiger60
blktiger60's Avatar
Drives: `08 HB S
No point in waiting till 6500 RPM's to shift. That's well past the power range.
Manual:
On the freeway today, on my way to work, I downshifted to 3rd floored it to 5800 and slapped it into 4th - plenty of acceleration. I didn't notice any latency. I know for a fact I can smoke the stock tires in first and get a chirp from second. Doesn't feel like DBW to me.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 03-05-2009, 09:06 PM   #16
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
I wasn't complaining about any lag, but 80% throttle with the pedal all the way down does bother me.
Old 05-02-2017, 07:41 PM   #17
DogetorHue
Drives: 2009 Silver Yaris Sedan
I know this is an old thread, but it would seem that the ECU is intentionally limiting throttle response. Take a look at this graph from one of the manuals...
DogetorHue is offline   Reply With Quote
Old 03-05-2009, 07:34 PM   #18
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
dun dun dun!
