![]() Drives: Toyota Yaris 1.33 TR Join Date: Jun 2017
cool warning light
hi,
last few days noticed the COOL light (greenish light) on the the dash display shows up when i start the car. After a few minutes the light goes out. I read this is no big deal just tells you engine is cool. BUT here its summer time it should not really be that cold wonder what will happen in winter? also noticed when setting off car seems bit jumpy, not getting as good a response from gas pedal but again after the cool light goes off this problem also seems to go. ps. is there anything i can do to increase the 'kick' well without expensive engine modifications? |
#2 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
#3 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
yeah it also determines when we hit 4th for the auto tranny peoples
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
#5 | |
Patience is a virtue, y'know!
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Any cars temperature will be low when first starting up after sitting for a period of time. There's nothing you can do about it. It's completely normal for this to happen. In winter it just takes a little longer to warm up.
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
The cheapest and easiest mod you can do is installing a block heater ($30~$50) and run it on a timer to activate 2-3 hours before your usual commute. If you don't work a fixed schedule (like me), then it's not always gonna help unless you leave it on 24/7 so it's always warm for when you need to roll out.
I was hoping for a picture of weird warning lights.. or a meme... I am disapointed
ok i only asked as when i bought for first few days this light never came on
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
That makes no sense. it should always come on and stay on for the first few minutes.
Sent from my phone. Please excuse any typpos. |
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
Maybe he was like me. I didn't notice the light was on at startup for the first couple of times I drove it. Probably was too busy getting my seat just right and my all important tunes loaded.
Kinda freaked me out at first. I thought it was a over temp light until I finally looked through the owners manual. |
ok myabe you are right..
but what about the non responsive gas pedal, when cool light is on. going up hill pressing gas and doesnt seem to move, very sluggish even if flooring the pedal. its not like clutch where you get lots of revs and no movement..the revs dont go up. its like it doesnt want to go and you really have to push it |
Wait till winter gets here, you'll really hate it! lol
#14 | |
The car doesn't want you to rev up the engine until the oil and cylinder walls are warm enough to get properly lubed, aka preventing you from wearing out your engine on cold starts. Let the engine run for a few seconds after startup before taking off, usually till the revs drop from 2k to 1.5k. Maybe 10 seconds in summer and 30 seconds in winter. Don't let it idle longer than necessary and drive it gently, without going above 2500 rpm/40km/h. That'll give you the best results. Also try to keep the electrical load on the alternator as low as possible until warm, as not to put additional drag on the engine. |
| Battery Warning Light - Different Twist maybe | RutherfordmanX | DIY / Maintenance / Service | 3 | 06-08-2015 09:59 PM |
| Yaris 2001 The engine yellow/orange warning light in the dashboard | cabbage2001 | DIY / Maintenance / Service | 11 | 01-16-2015 07:53 AM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 05:27 PM |
| windshield warning light...? | yaris user5Mottyl | General Yaris / Vitz Discussion | 1 | 05-31-2012 11:23 PM |
| Explination point(?) warning light... | dodgerblu88 | DIY / Maintenance / Service | 1 | 03-04-2012 08:18 AM |
