![]() Drives: 2016 Yaris L Manual Join Date: Mar 2016
Squeaking Clutch Pedal / Linkage & Squeaking Shifter
2016 Yaris L
2 - Door 5 Speed 56k Miles (A LOTTT of highway trips) Cruise Control courtesy of CTScott ![]() My shifter / shift linkage squeaks between 1st and 2nd Gear Also, the clutch pedal makes a squeak when pressing the pedal to disengage the clutch *** Has anyone had this issue with their car? *** Does anyone know what the fixes for these conditions are? |
2ZR swap. DO IT! Ask how!
I have similar issues on mine. Probably just needs to be greased, but mine is an '09. A '16 shouldn't need that already.
![]() ![]() Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
It's the rubber seal where the clutch link goes through the firewall, just spray a bit of WD40 onto the rod connected to the clutch, press it a few times and it should stop.
Sent from my SM-N910F using Tapatalk |
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
Had same issue, sprayed some all purpose silicone lube on the shift linkage bushings in the engine bay and it stopped squeaking for about a month(pulled off the linkage and lubed it up after). Same 1st-2nd squeak as you are experiencing.
| YARIS Clutch Pedal Noise | mik23 | DIY / Maintenance / Service | 3 | 04-27-2022 09:41 AM |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 04:59 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 11:42 AM |
| Micro Image Short Shift Kit DIY | jpmck03 | DIY / Maintenance / Service | 17 | 02-24-2014 08:57 AM |
| Sqweek while shifting (MANUAL) | dallas | DIY / Maintenance / Service | 43 | 09-01-2010 04:57 PM |
