Old 10-15-2017, 08:30 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Should I replace this small piece of brake line?
I had worked on the master cylinder many times, and pushed it in and out with the lines attached to see if there is a leak. I had a stripped nut and replaced it by cutting the flare and using another nut I had laying around. I am just worried about the line near the back connecting to the mc. I moved it so many times, and when it was replaced, had a small kink from bending but no leaks. It moves from the bracket being moved. Should I replace it or leave it alone? It has been fine for the past two weeks.
File Type: jpg 22207396_1563333053712475_1389795178_n.jpg (60.8 KB, 55 views)
File Type: jpg 22199399_1561766357202478_527757992_o.jpg (189.6 KB, 55 views)
xdarkxfirex is offline   Reply With Quote
Old 10-16-2017, 08:35 AM   #2
ex-x-fire
Well, it's not to hard to change that rear one. For peace of mind reasons.
Old 10-16-2017, 07:55 PM   #3
xdarkxfirex
Its pretty badly stuck on the union. Couldnt get it off with my flare wrench, and toyota makes you buy a set of lines not just one. I guess im better off leaving it if it isnt leaking.
brake line, fluid, kink
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 04:35 AM
Question on brake bleeding... Yarflana DIY / Maintenance / Service 6 04-03-2013 02:55 PM
Beware of the "simple" brake job tasks Yarflana DIY / Maintenance / Service 7 03-18-2013 03:26 PM
Front brake pad replace: calipers piston dslc DIY / Maintenance / Service 3 07-17-2010 03:46 PM
