Old 10-13-2015, 01:26 PM   #1
Sal_JapMechanic
Drives: Toyota Yaris/Vitz 2005
Need speedo with tach and with 220 km/hr range
Hi i have yaris 2005 with 1krfe motor. I currently have ugly looking speedometer and it dosnt have any tach either. I need a speedometer with tach and with 220 km/hr range and with temperature display. Mine is an auto transmission. Where to find and is it compatible would it be a bolt on thing? I dont have ECO thing. I need someones help here doing this
Waiting for your comments.
Thanks
Sal_JapMechanic is offline   Reply With Quote
Old 10-14-2015, 08:54 AM   #2
jcboy
Drives: Sedan 07
Your best bet would be your local junkyard from a higher trim level.
Old 10-14-2015, 10:19 AM   #3
Sal_JapMechanic
thanks
Thanks for your reply... Yup ur right.. i will look for it but m afraid i have all jdm stuff here and the cluster i need is canadian or usdm.
Old 10-14-2015, 10:46 AM   #4
You will not find a cluster that meets your listed requirements on North American shores.
Old 10-14-2015, 12:31 PM   #5
Sal_JapMechanic
Thanks for your comment. Then what do you suggest? and how one should check compatibility? tach and 200 km/hr range is what i need. Mine is an auto to P,N,D,S,B indication on the speedo as well with temperature reading.
Old 10-16-2015, 09:56 AM   #6
Sal_JapMechanic
Bump!!!
Old 10-16-2015, 08:15 PM   #7
Is your car right hand drive? Also, is it a first or second generation Yaris/Vitz?
If it is a second generation, I am only aware of the temperature display being on the digital instrument cluster, and that actually has a tachometer.
Old 10-18-2015, 03:53 PM   #8
Sal_JapMechanic
Thanks bro
Yes its a second generation and yup its RHD. Can you show a pic of that cluster ur referring to? Thanks alot for your comment.
Old 10-18-2015, 07:36 PM   #9
Old 10-19-2015, 01:50 AM   #10
Sal_JapMechanic
This one looks cool however i would want something like this for my auto yaris 2006 second generation. I want this one.
Old 10-30-2017, 03:06 PM   #11
ACKING_QC
Drives: 2018 VW TSi Stage1
Iam VERY SORRY to bump that thread but... HOW did you changed the color of it? it's a turquoise color normally..... how did you turned it to blue ??
ACKING_QC is offline   Reply With Quote
Old 10-19-2015, 01:52 AM   #12
Sal_JapMechanic
Also i have noticed my seat belt warning chime and its warning light on the speedometer are not working. Dunno whats wrong
Old 10-31-2017, 01:21 PM   #13
IllusionX
Drives: 07 Yaris Sedan Aero
Buddy. Turn down the brightness of the cluster lighting.
Sent from my SM-G930W8 using Tapatalk
Old 11-01-2017, 11:51 AM   #14
ACKING_QC
what the ??
this CANNOT be done on the digital cluster it stays at max brightness all the time due to it just being an LED screen with cutouts
Old 11-01-2017, 03:09 PM   #15
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
Originally Posted by ACKING_QC View Post
what the ??
They dim when you turn your lights on. But what he thought is that the brightness of the cluster was bugging you with your new sear, and not the actual height. I think I covered your questions well. Cheers
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 10-31-2017, 05:18 PM   #16
vivalaflam
Enthusiast
vivalaflam's Avatar
Unfortunately it's fixed. Also, you don't have to disassemble it at all. You can even take out the clear plastic without even unplugging the speedo, just unscrew it, tilt it towards you, and there are some tabs holding it in place. Try putting some coloured films on the speedo to see the result, till you find the combination that you like best, and then you can stick it in place. It's one of the easiest mods you can do. If you want an analogue cluster that's a really hard thing to do if you wanna change the colour. The analogue clusters have smd leds on the circuit board. I have some pics if you're interested
Cheers, George.
