Old 11-08-2017, 05:40 PM   #1
la_scanner
Drives: 2007 toyota yaris
Question The fuel injection system, the throttle plate has a lot of carbon build up
2007 Toyota dropped off at Toyota because the left rear turn signal is not working. Bulb and socket were not the issues. Also, needed new windshield wipers.
Well, they called and talked my mom into this...
"The fuel injection system, the throttle plate has a lot of carbon buildup on them. When it builds up with carbon like that it reduces the amount of air that goes inside the engine, and it drops the idle and the gas mileage, so if the car stalls out it could be because the throttle plate is getting stuck."
No mention of turn signal or wipers, but spark plugs and cleaning the throttle plate are costing $395.00. Did they pull a fast one and then some?
la_scanner is offline   Reply With Quote
Old 11-08-2017, 05:54 PM   #2
nortonfb
Drives: 2007
Sure did.
Avoid that place.
nortonfb is offline   Reply With Quote
Old 11-08-2017, 09:44 PM   #3
SirDigby
Drives: 2007 yaris 3 door
the throttle plate is not part if the fuel injection system, it is part of the air induction system. there is not anyway for carbon to build up on the throttle plate because the 1nz-fe does not have an EGR system. the only thing that passes over the throttle plate is air, maybe a little dust, and maybe a little oil from the PCV system. spark plugs are about $25 each, i think it's .5hrs labor. should run around $150-$175 for dealer to replace. $200 to wipe off the throttle plate? are you sure she didn't get an induction service too? that runs about $250 and cleans throttle body, intake manifold, top of pistons and valves. if it's a BG service, it works very well, but is not needed on a yaris unless the car spends a lot of time idling and driving at low RPM's for over 200,000 miles or the use of poor quality fuel for extended period of time.
turn signals and wipers are a safety concern. they should have been checked first. always get a second opinion on any "service."
fuel injection, gas mileage, throttle plate, toyota
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
