Old 10-25-2017, 09:08 AM   #1
Lux
Lux's Avatar
Drives: NCP91
Giving away: Toyota FIPG, Pematex black/grey, genuine Toyota axle nuts
Giving away genuine Toyota liquid gasket, also called FIPG (Form In Place Gasket, P/N: 00295-00103) and Permatex equivalents in black and grey variations. The Toyota stuff is the absolute best in the industry, by far. General Motors dealerships buy it from Toyota to supercede the crap they buy from Germany. I get one for every couple engines I rebuild and I don't need that much.
I also get a new genuine Toyota axle nut for each engine as well, but don't need them. Axle nuts are 30 mm 12-point double hex external drive, M22 x 1.5 thread pitch, fits virtually all Toyota and most Asian cars.
Lux is offline   Reply With Quote
Old 10-25-2017, 10:07 AM   #2
tmontague
tmontague's Avatar
Can pick some up from you this Saturday. That FIPG will be perfect for my new trans, as will the axle nuts
Old 10-25-2017, 01:56 PM   #3
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
^ There's a different formula used for transmissions, it's orange; 00295-01281
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 10-25-2017, 02:41 PM   #4
tmontague
tmontague's Avatar
Good to know, what would the fipg typically be used for?
Old 10-25-2017, 03:00 PM   #5
Lux
Lux's Avatar
Drives: NCP91
Yup, the orange FIPG deng mentioned is called # 1281 Seal Packing, which is for use on drivelines. In theory the black silicone will work as well on almost anything. The difference in colour and formulation is to distinguish its resistance to the fluid, temperature, or vapour in its intended environment. I have an unopened tube of 1281 that you can take on Saturday, tmontague.
Old 10-25-2017, 07:18 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That's very kind of you, Lux. What a great site we have here.
Old 10-26-2017, 10:21 AM   #7
macmotano
SUPER bannned
Drives: Stock
I'm not mechanic, so no idea on how to rebuild engines. but Thank you and nice to have you here
macmotano is offline   Reply With Quote
Old 10-27-2017, 05:37 AM   #8
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
How much to 62100 Greece?
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 11-05-2017, 06:03 AM   #9
mehullica
Drives: Yaris 3-door
I would be happy to take some FIPG. Yaris & Echo has leaking timing covers, sisters 3.5 Camry timing cover leaks too. Are you shipping to California?
mehullica is offline   Reply With Quote
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Toyota: The Most American Car Company Kal-El Off-topic / Other Cars / Everything else Discussions 18 07-10-2009 12:01 AM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
