![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
what do you think about this???
2nd hand manifold...but i dont know why its rusted.....you think its alright? how can i test if its alright? hit it with the hammer few times to check? should i get heat wrap and wrap around it??
![]() ![]() Sent from my SM-J730GM using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
Digby, that would be an exhaust manifold.
By looking at it, I would guess it was bare steel that someone left out in the weather. I would use it, but take a wire wheel to the mating surfaces first. Looks like it is just surface rust to me. Last edited by white89gt; 11-01-2017 at 02:41 PM. |
I thought at first a header and then I thought intake and settled on that
