Old 10-30-2017, 09:41 AM   #1
mik23
Drives: yaris 2005
Coolant advise
Hi
Can anyone advise please re the coolant i think i need top up
Sent from my SM-G930F using Tapatalk
mik23 is offline   Reply With Quote
Old 10-30-2017, 12:04 PM   #2
bronsin
bronsin's Avatar
To top up just about anything will do as long as it says compatible with all types on the bottle some where. The Toyota red or pink stuff is good for a very long time in my experience.
Old 10-30-2017, 01:51 PM   #3
tmontague
tmontague's Avatar
Stick with Toyota pink I wouldn't advise mixing coolants. There is a company called "OEM" that is sold out here in Canada that makes coolant for all brands and their Toyota/Lexus stuff is has the exact same ingredients as the factory Toyota stuff according to the MSDS sheet.
Old 10-30-2017, 01:53 PM   #4
mik23
Drives: yaris 2005
I think pink is llc
Old 10-30-2017, 07:49 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If it's only slightly low just top it up with distilled water.
Old 10-30-2017, 08:10 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
This. I believe it's the water that evaporates anyways.
Old 10-30-2017, 08:06 PM   #7
mik23
Drives: yaris 2005
See attached i think i need top up
Old 10-31-2017, 07:41 AM   #8
komichal
If it happens only once you can just use distilled water.
If you are flushing complete system then give it whatever there was before.
If it was pink, let it be pink.
While original Toyota is obviously the best, you can use virtually any pink coolant available.
Old 10-31-2017, 03:44 PM   #9
white89gt
Drives: 07 Yaris Hatch
Does anyone know the total capacity? The radiator sure is small....
This stuff works for pink... https://www.amazon.com/Pentosin-8115...s=pink+coolant
white89gt is offline   Reply With Quote
Old 10-31-2017, 05:35 PM   #10
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
From a 2007 sedan manual...
Here is a direct link to the Toyota manuals...
https://www.toyota.com/owners/resour...als/yaris/2007
Old 11-01-2017, 02:25 PM   #11
white89gt
Thank you!!!
Old 11-01-2017, 04:51 PM   #12
06YarisRS
Thank you!!!
Yer welcome.
Old 11-01-2017, 10:28 PM   #13
xdarkxfirex
Drives: 2015 yaris le
If its just a tiny bit, I just use regular water or better distilled water.
xdarkxfirex is offline   Reply With Quote
coolant reservoir/upper radiator level tmontague DIY / Maintenance / Service 4 11-05-2014 10:11 AM
Various problems with service at shop (green coolant and accelerator rattling noise) LilyOfTheYaris DIY / Maintenance / Service 4 04-08-2014 11:31 PM
Khameleon Coolant? LilyOfTheYaris DIY / Maintenance / Service 18 04-08-2014 11:27 PM
Alternatives to Toyota "pink" super long life coolant Camberix DIY / Maintenance / Service 10 03-30-2011 12:42 PM
coolant reservoir? toad DIY / Maintenance / Service 10 11-02-2010 12:02 PM
