![]() ![]() ![]() Drives: 2016 Yaris 3 Dr Super White Join Date: Mar 2016
High Speed Stability
I’ve noticed while driving at speeds in excess of 70 mph my car seems to float/wander. The suspension is stock and I know from previous threads that my tires aren’t the best tread pattern. I’m living with my tire purchase until I can afford/have to replace them. Would using stiffer springs and lowering the car with a rear swaybar help with my issues? I know it’s a pretty light car to begin with and I find it get’s more enjoyable to cruise fast with more weight, ie. A full tank of gas. Thanks guys!
Wait for the next BIG sale at discounttiredirect.com and snatch a good set of tyres at a give-away price. Then, sell your old tyres on craigslist; you'll be surprised how much you'll get.
This was my last purchase: 4 Kumho Ecsta 4x ll (205/50/16) @ $83.36 each = $333.44 -$75.00 (dtd Memorial Day Rebate) -$60.00 (Kumho Tire Rebate) -$60.00 (dt c/c Rebate) Total = $138.44 BTW: With these Kumhos, no rear anti-sway bar, and stock suspension, I can cruise at high speed confidently with no highway wander and no sense that the car is floating. |
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
205/50/15 and Eibachs springs, high speed is still unstable on my 13. High speed tight turns, braking and emergency maneuvers improved a noticeable amount but the 70+mph highway driving feels unstable. It has had that unstable feeling since stock, and the dang throttle lag that drove me nuts until i adapted to it.
Just a Gaijin
I never felt like changing the suspension because of instability and i drove 120mph on the Autobahn. However i changed my wheels and tires from 185/65/r15 to 205/45/r16. Which defenitely improved stability. I have a 2006 Yaris thought.
#5 | |
Kumho Ecsta PA31
Do you think they changed the alignment specs for the 14-up Yaris?
I wouldn't think so. But, I'm certainly not versed in this area.
My 2007 was scary to drive over 70MPH for any length of time. I changed from the OEM steel wheels and 185/60/15's to 16x7 alloys and 205/50/16's. That greatly improved overall handling, but didn't eliminate highway wander or that sense that the car was going to float away on me. I installed a TRD rear anti-sway bar and that changed the entire handling dynamic; great cornering and somewhat improved high speed stability. But, the car was still a heart in your mouth experience at speeds over 70MPH. Then, I began experimenting with various 205/50/16 tyres and discovered that tread patterns can make a huge difference on the highway. With the "proper" rubber, I could confidently drive my 2007 at 85MPH all day long (with no anti-sway bar BTW). I have the same experience now with my 2014. |
I always had 195/55R15 Yokohama S.Drive on my 07, and never felt unstable excess of 70mph.
Sent from my SM-G930W8 using Tapatalk |
Yokohama S.Drive works REALLY well on the Yaris!
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Anyone tried Yokohama YK740 GTX tires? Those are the ones that I'm partial towards for my first tire replacement next year, to replace the factory SE Bridgestone tires.
I’m running Sumitomo A/S - 205/50r16. I am driving between Naples and Miami on the 75 (Alligator Alley). It is like the Autobahn out here. People are doing 100MPH most of the time.
I’ll look into those Yokohama’s, they look pretty good.
Is there a all season variant of the S.drives? A tire that can handle some light snow.
Just a Gaijin
Just a Gaijin
Also you guys might wanna check your tire pressure. Sometimes manufaturers recommend different pressures for high speed driving.
My 2006 Yaris doesn't, but i know that for my parents 2016 Auris they recommend two different pressures, depending on how fast you drive. Recommendation for the Auris: "For speeds of 99mph or less, the front and rear tyres should be inflated to 33 psi. For speeds above 99mph, the front and rear tyres should be inflated to 38 psi." |
#18 | |
Although, i wouldn't trust them in any snow. They are marked as high performance all seasons. Sent from my SM-G930W8 using Tapatalk |
| steering wheel slight vibration high speed??? | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 10-01-2012 06:36 PM |
| HIGH SPEED YARIS CRASH.... | ROCKLAND TOYOTA | Photo-Video-Media Gallery | 23 | 03-10-2012 08:59 AM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Have I mentioned how much I hate Speed sensors? | staticorex | General Yaris / Vitz Discussion | 13 | 05-28-2009 04:04 PM |
| Six speed | Snyprwlf47 | Performance Modifications | 16 | 11-24-2008 09:04 PM |
