18k km UOA on Mobil 1 0w30
![]() I currently have Pennzoil ultra platinum 5w30 in my engine and have noticed it is a bit quieter and takes a bit longer to warm up. There doesn't seem to be any significant changes in oil pressure between the two, if anything maybe 3-5 psi higher in the Pennzoil, but I can't confirm that. After reviewing the oil samples I am impressed with the 2zr being another solid engine. Wear metal were well within spec. I am also impressed with the 0w30 Mobil 1 oil holding a really decent total base number (TBN) and being able to handle 18k km of track days, extreme cold and hard driving and be able to go even longer. You can see the viscosity is starting to come down over time. This isn't a concern for me if I only DD my car, but I wouldn't put more track days on the car at over 18k km on the oil with the viscosity dropping. It is still well within spec and I'm not saying it's a concern but I wouldn't want to push that limit on a track with my DDer. Going forward what I think I'm going to do is run Mobil 1 0w30 for up to 21k km but only during the winter months (~Nov-early Apr) and run Pennzoil UP 5w30 in the summer and during the track days. The plan is to just drain and store the oil when not being used. I plan on starting with a 12k km OCI on the Pennzoil UP after a hard summer of track days and see what the result is.
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Looking great man, nothing to be concerned about here.
I would like to see the comparison of a 5w30 to this, to see if there is a difference in wear metals. We already know that my 10w40 sample results looked similar to yours, so this makes me think that any weight oil we use will provide similar results. So if most synthetic oils produce the same amount of protection, and so do different weights.... Does it not matter at all what oil we put in our engines? |
Your question is exactly what I was going through in my head earlier today.
Oils have come a long way the last decade. Are we nearing the point of not needing a really heavy weight race oil? Is it possible that much of this has carried over from old technology and just stick with us even if it is no longer relevant? Questions worth asking
Data doesn't lie
I believe you’re right.
I even asked Blackstone if the results showed I needed an oil cooler.....they said no. |
| UOA Yaris sedan w/ 175k km | tmontague | DIY / Maintenance / Service | 1 | 02-21-2017 05:23 PM |
| Changing Engine Oil (Mobil) | lijet | DIY / Maintenance / Service | 1 | 07-05-2012 03:01 PM |
| Mobil 1 Oil Change Special SALE @ Advance Auto Parts | aca72 | DIY / Maintenance / Service | 1 | 03-09-2009 12:10 PM |
