Old 11-09-2019, 12:49 PM   #1
Bikerboy89
Drives: 2015 Yaris Liftback LE auto
Loud belt squeal when cold
Hello I have never had a car do this so it's a little surprising my 2015 yaris automatic is with such low miles (57k). If it's squealing for a while after it starts (like 10 seconds) does it mean it needs a new belt or is there a way to tighten it up a bit? It only does this after a cold start and it's already in the 30s here in Michigan.
Bikerboy89 is offline   Reply With Quote
Old 11-09-2019, 02:53 PM   #2
Typical. Needs a bit of tightening.
Old 11-09-2019, 03:40 PM   #3
Bikerboy89
Thanks I see on the alternator the bolt on top with the groove. Is there another bolt to help loosen it?
Old 11-09-2019, 05:09 PM   #4
Loosen the top alternator mounting bolt. Using a small pry bar, or similar item, CAREFULLY pry alternator forward. I say carefully because it is very easy to inadvertantly damage the OCV mounted in the engine block behind the alternator. There are numerous threads on here with people questioning 'what is this thing I just broke?' as a result of trying to tighten their belt.
Also, before loosening the bolt, on the slotted bracket, mark the current position of the bolt so you can monitor how much you are moving it.
Old 11-10-2019, 11:15 AM   #5
Bikerboy89
Thanks a lot!
Old 11-13-2019, 01:18 PM   #6
dogsridewith
Drives: 2007 2-door hatchback
serpentine belt squeal tighten alternator bracket
Need to loosen both bolts. A 13-14 inch channel lock plier works better for tightening than a pry bar, and isn't near anything it can hurt...one jaw on curved slot bracket end, other jaw on alternator at bolt boss.
Old 11-13-2019, 01:22 PM   #7
Bikerboy89
Thanks sir! After reviewing the service manual I realized I would have to loosen both bolts. I did just use a prybar I only moved it a little bit and the squeal is gone for now. So you know if there's a position on the bracket that's considered too far where the belt would need replaced rather than just tightening more? Also when summer comes back around you think I'll have to loosen it a bit?
Old 11-13-2019, 02:05 PM   #8
First off, you do not need to loosen both bolts. Several years ago Toyota released a TSB regarding belt tension. In the outlined procedure to mechanics it specifically stated loosen top bolt only. The alternator will pivot on the lower bolt without loosening which is great since it is a pain in the ass to get to with your average set of tools.
No, there is no point on the slotted bracket which indicates too far.
No, you will not have to loosen it in the spring.
Old 11-13-2019, 02:09 PM   #9
Bikerboy89
Thanks for the information. The only reason I ended up loosening the bottom bolt too was when I tried prying it it wasn't moving and I was worried about snapping something off. Maybe I was just being too timid with it because I read elsewhere online also, someone broke theirs off.
Old 11-13-2019, 02:22 PM   #10
http://www.yarisworld.com/forums/sho...31&postcount=1
Old 11-13-2019, 02:36 PM   #11
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
happened to me earlier this year, lol.
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 11-14-2019, 09:57 AM   #12
dogsridewith
serpentine belt squeal tighten alternator bracket Mind of Toyota
Shop manual says loosen both bolts. Yes, on many random cars of all types the lower bolt is loose enough that you only need loosen the upper one for belt adjustment. On this new-to-me 2007, that's what I did first. But the alternator position was just frozen until I loosened the lower bolt. Used a correct sized socket on a 3/8 drive ratchet wrench w/ a piece of one-inch aluminum tube as a cheater to gain a little length...just enough room for one click per rotatation. (Best might be a long enough 12 point box end wrench w/ the right bend for access.)
Now that I know a tool to use, I do tighten the lower bolt. Also can see why Toyota dealers would rather prefer to avoid those steps to save time by leaving the lower bolt sorta tight.
The manual instruction to use a pry bar but w/ care not to hurt that part is bad advice...many or most people doing the job will have trouble finding the vulnerable part.
Belt Squeal mystery solved Carquestions DIY / Maintenance / Service 7 05-04-2016 06:27 AM
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 07:19 PM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 11:41 AM
07 HB Mechanical Noise Cold Squeal Fidelio DIY / Maintenance / Service 0 09-13-2012 12:29 AM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 06:50 AM
