![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
Slightly Low Coolant, Should I Flush or Top It Off
Hello,
Recently my friend noticed the coolant in my Yaris was a little bit below the line LOW line, but I only have 70k miles so it is not due for a replacement. I want to fill it back to the appropriate level, but am not sure of what type/brand of coolant was put in previously. Any idea of what are the best steps I can take here to avoid any issues? I would have no problem flushing the system, but ideally would like to avoid it. |
Buy yourself a mixture with water 1:1 of G12+ (pink one) and pour it in. The brand is not that important.
For a full flush the guys here would recommend to go only with OEM Toyota coolant but if you just need to add a bit then you can use anything. I did a full flush recently and used Sheron as the Toyota stuff costs a fortune while there is no measurable difference. |
#3 | |
Keep in mind the cooling system in the yaris is not a sealed system so losses due to evaporation do happen. Every year you'll probably find you are down a few ounces
#5 | |
#6 | |
Will be checking for this, thank you for pointing it out. Hopefully, it is just as tmontague said and it was due to evaporation. |
I remember once quite a gulp of coolant "disappeared" from my coolant reservoir in one week or so. I poured in some distilled water and it has not moved a bit since then. It is been on the same level over a year already. Who knows why car spitted that out before.
^^^yes. top off with distilled water. it's like $0.60 a gallon.
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
Just make sure what you put in there guys ,
mixing OAT coolant with HOAT coolant makes a reaction turning your coolant to a Jello like substance ==> big troubles getting that removed from Inside engine . |
| Coolant flush procedure? | BennyLava | DIY / Maintenance / Service | 24 | 11-20-2014 05:11 AM |
| Help ASAP!!!! low coolant indicator | MeggiemobileSFLA | DIY / Maintenance / Service | 29 | 08-03-2013 01:09 AM |
| Query re: low level coolant indicator | tracey540 | General Yaris / Vitz Discussion | 2 | 05-12-2010 06:01 PM |
