Speaker Wire Gauge?
Does anyone know the actual gauge of the speaker wire in my '06 Yaris? I'm about to start my audio installation. I had a door panel off and the speaker wire looks quite thin. My amp is 4 x 100 watts and I rarely crank my systems up so I'm hoping I don't have to replace the wire.
Thanks in advance.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
100 watts into 4 ohms is only 5 amps. The speaker wires don't need to be very heavy gauge, but it won't hurt to upgrade the wiring if you want to. Just don't expect to hear any great change in sound if you do upgrade the wiring.
Even allowing for the poor efficiency of most car speakers, 4x100 watts would be causing hearing damage if you were using the full power...
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#3 | |
According to the site linked below, I should have 18 gauge wire. I would guess that the wire in the Yaris is 20 gauge or possibly even 22 gauge. It's thinner than both my Kia vehicles and thinner than the wire was in my older Dodge minivan. I expect that they are assuming that you will be actually using the rated power of the amp - a 'safety margin' of sorts. http://www.bcae1.com/wire.htm
Unless you are installing your amp in stock location, you probably want to fish new wires to the door anyways. Run 12-10AWG
Sent from my SM-G930W8 using Tapatalk |
#5 | |
Thanks for the input. 12 gauge would certainly be more than adequate, I expect. I'll consult with the stereo install guy too.
| DIY keyless entry Viper 211HV w/ pics | tmontague | DIY / Maintenance / Service | 24 | 07-06-2025 08:13 AM |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
| 2009 4dr. LB Speaker Wiring Question | AutoXBot | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 05-09-2010 09:48 PM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| Power wire gauge vs stereo wattage | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 02-24-2009 02:16 PM |
