![]() Drives: hatchback manual transmission Join Date: Dec 2015
Rear clunking on coilovers
Hey guys. since i installed my coilovers about a year ago i've been getting a clunking sound from the right rear shock tower. After months and months of trying to find a solution i finally gave up and ignored the sound. However, i just realized the bump stop on the shock is misaligned a little bit. How hard would it be to loosen the shock and realign the shock/tighten it back down in place? Im thinking this is what is causing that loud "THUD" sound whenever i go over a little bump in the road.
To loosen and realign simply undo the 14mm (or 17mm I can't remember) bolt on the bottom of the rear shock/axle and then from the inside loosen the upper shock bolt. You can then move the bump stop as you wish
Awesome, do you think I'll need anything more than a breaker bar for the bottom? Also should it be on a jack? I'll try and report back today with the results.
#4 | |
Also, i took it for a 30 minute drive around town and the loud metallic "THUD" sound seems to be gone except in areas where the shock has to compress quite a bit (maybe when it bottoms out). Even took it over railroad tracks and didnt hear the distinctive noise. I dont think it should be too much an issue to replace the shock, i'll just have to contact Megan Racing for a replacement. Thoughts anyone? |
#5 | |
![]() ![]() Drives: 2007 Yaris hatch Join Date: Jun 2017
| Rear Wiper Intermittent Delay Timer Mod | toy_toronto | DIY / Maintenance / Service | 36 | 07-08-2016 09:04 AM |
| FS Cusco coilovers, ultra rear sway, gt spec bracing, miracle x cross bar seibon hood | blacksandiegovitz | Items for Sale by private party | 23 | 10-24-2015 12:47 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 06:02 PM |
