![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Radiator Hoses - Gates - Molded
Hi All...
Planning to change the coolant on my 08 Sedan and since the car has 210,000km, I am going to change out the main radiation hoses(2 x upper, and 1 x lower)... Has anyone tried the Gates hoses? and how well molded are they to the OEM shape? Thanks! |
I've used Gates on numerous vehicles. Can't ever recall an issue.
Is there a particular reason to change hoses after some mileage? As long as they are not leaking, not cracked and not extremely soft or hard, I would be quite satisfied with keeping them as they are.
#4 | |
Sent from my VTR-L09 using Tapatalk |
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
"Provided it's 10years old"
I always change all my main hoses during every flush. Usually every 3 or 4 years. The Yaris' hoses are so inexpensive it's a no brainer. This winter I will throw a set of hoses in a cart at rockauto and wait for a good coupon. Will be ready for next summer. |
#6 | |
Just what IllusionX said..
The hoses appear ok.. just a PM .. Quote:
![]() ![]() ![]() ![]() Join Date: Feb 2010
Be sure to use the Toyota super duper red coolant....it is supposed be less harmful to to the rubber.
