Old 12-14-2018, 08:15 PM   #1
James Yaris
Drives: 2007 Yaris 3dr hatchback
Ac Question
Hello to all! I have been a long time watcher of this forum and finally decided to join. You all are awesome! I have been inspired and have learned a ton about the little car I have grown to love.
I have the strange rattle coming from what appears to be the Ac compressor clutch/pulley on my 2007 Yaris 3dr hatchback. I found a part on Amazon to replace the pulley assembley. It is made by Autex. AUTEX AC A/C Compressor Clutch Coil Assembly Kit 88310-52481 Replacement for 2007 2008 2009 2010 2011 2012 Toyota Yaris 1.5L. Has anyone else had any experience with this part from this manufacturer?
It appears to me that the Ac is stuck on and the clutch is not disengaging. I took a jumper and actuated the solenoid on and off and never heard it/saw it disengage. I then had a friend turn the Ac on and off while i watched the pulley. Still not disengaging, but yet the engine pulses like the ac is cycling on and off while I run the defrost. I have read about the remanufactured Ac compressors that can be picked up for about 150 usd on the internet. What is the best route to go? Buy a remanufactured unit, or try to replace the pulley and clutch assembly?
I live in Wisconsin where it is cold right now. I bought a serpentine belt for a Yaris w/o Ac planning to disable the Ac until i can figure out the issue so i dont damage the compressor if the bearing in the clutch seizes up. Is there anything else I would need to do to disable the Ac compressor like removing a fuse or a relay? Or am I good just using a belt that bypasses the pulley, knowing the car uses the Ac to boost the defrost.
I am an Industrial Maintenance Mechanic by trade so i am pretty sure i will be able to repair the compressor clutch if I pull the compressor but is it worth the time and effort?
Thanks again for any assistance.
James Yaris is offline   Reply With Quote
Old 12-14-2018, 08:57 PM   #2
tmontague
tmontague's Avatar
There is no magnetic clutch on 2nd and 3rd gen yaris'. The clutch always appears to be spinning regardless of activation or not.
If the rattle is from the compressor it could be a bad bearing. Imo just her a reman'd aftermarket unit for just over $100. Just make sure the compressor is the problem first.
Old 12-14-2018, 10:05 PM   #3
James Yaris
Thanks much Tmontague....makes sense if there's no magnetic clutch that it would be spinning. I will have to dig a little deeper and see if i cant figure it out. Would you know anything else I would need to do to disable it for now, other than replace the serpentine belt with one for a Yaris w/o Ac? Re-pull the fuse or relay or jump something out so it thinks its not there for now? I spun the water pump by hand and that's spinning smooth and freely w/o belt on so i'm pretty certain the rattle is from the compressor. I found this remanufactured Ac compressor on the internet, has anyone bought from these guys? https://www.rycompressors.com/shop/2...hoCyFoQAvD_BwE
Old 12-15-2018, 10:00 AM   #4
dogsridewith
Drives: 2007 2-door hatchback
Yaris HVAC clutch
Some rotating element there has to have spinning and not-spinning states, or there is no clutch...maybe something we're used to seeing on other A/C clutches is just hidden from view?
Nice to know that the alternative belt bolts right in.
Did the A/C stop making cold air?
Old 12-15-2018, 10:29 AM   #5
tmontague
tmontague's Avatar
From my understanding there is not really a clutch, it is an internal mechanism that "turns on" or off.
To disable it but keep it charged you can just run a shorter mon a/c belt or pull a fuse or pull the elextrical connector on the compressor
I've never purchased a reman'd unit from that website but I bought a cheap $110 ebay reman'd compressor when I did my 2zr swap and I've had no issues with it.
Old 12-15-2018, 12:00 PM   #6
James Yaris
Thanks for the help with this guys. As far as I can tell the Ac compressor is putting out cold air, but the temperature outside is 29 degrees right now so its hard to be positive. I'm judging my assumption based on how effective the car has been at clearing the frost off my windshield before the engine is fully warmed up. The Ac was strong and cold when I used it over the summer. Sounds like either way I do this the compressor will need to come off the car eventually, just hoping its not when my ass is frozen to the pavement but rather when I can do it in comfort.
Old 12-15-2018, 12:40 PM   #7
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Heat your car up inside really well and turn on recirculate, then AC. It will draw warm air from inside and cool it. You'll see the difference. That's what I'll be doing when I finally get new compressor installed and the system recharged.
Oil Feed Line Question? MugenRep Forced Induction Forum 5 01-26-2017 09:06 AM
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 09:28 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
