![]() Drives: Yaris 2007 Hatch Join Date: Apr 2018
Fuel economy in extreme cold temperatures.
Hi everyone, just wondering what kind of mileage everyone is getting with the recent cold temps.
I just hit my worst tank in years, with 9.5L/100km, 24.8mpg, with temps from -28 to -40C. |
#2 | |
![]() Here is the most recent thread on fuel economy: http://www.yarisworld.com/forums/showthread.php?t=61576
#3 | |
3 Yaris and counting..
My first 1/8th bar usually go 130km or so when I'm not heavy footed. This tank got me 53km XD
Sent from my CLT-L04 using Tapatalk |
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
We had temps about -34C to about -26 (daytime) and I got about 28mpg. During summer, I can get 40-42mpg pretty easily.
Extreme cold starts and fuel mileage
Are you guys in extreme-cold areas parked indoors and/or fitted w/ block or coolant heaters of some sort?
Do your cold Toyotas make any odd buzzes or rattles after firing up? |
I don't plug my vehicles in anymore. I used to put them on a timer with 4 hours heating before startup. During a cold snap, I'll start and run a vehicle if it's not going to be used for a few consecutive days. Sometimes my van will make a little bit of noise, similar to a power steering pump low on fluid, but it usually lasts for only 2 - 3 seconds. Then, it's quieter than when it's warmed up and the oil thins a bit.
I park outdoors and don't have any heaters. When it's really, really cold I can get some wheezing/whirring at startup but it goes away after 5-10 seconds, typically.
| Fuel economy gone down ? | JudgeM | Fuel Economy Forum | 9 | 07-12-2015 02:09 AM |
| Help me with my deteriorating fuel economy | mygirlYari | Fuel Economy Forum | 12 | 06-04-2014 02:27 PM |
| Fuel Economy Reports | KentSzabo | Third Gen Yaris General Discussion | 127 | 07-21-2012 04:17 PM |
| Fuel Economy Forum | peterreabok | Fuel Economy Forum | 1 | 12-14-2011 04:36 PM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 10:20 PM |
