Old 04-05-2019, 10:20 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Why You Shouldn't Run on Empty
This Is How Much Gas You Should Be Keeping in Your Tank:
https://www.msn.com/en-us/autos/owne...cid=spartanntp
Old 04-05-2019, 02:03 PM   #2
KALISPEL II
KALISPEL II's Avatar
Drives: '26 Mazda 3 Select-Sport Sedan
I've always been one to fill back up somewhere between 1/4 & 1/2 tank. I don't like the thought of running out of gas while trying to make my getaway.
Plus, 13 Ways You’re Shortening the Life of Your Car:
https://www.rd.com/advice/how-youre-...dium=ad-rd-msn
2026 2.5L NA Mazda3 Select-Sport Sedan 6-AT FWD (w/Chrome-Delete) - Soul Red Crystal Metallic - Built in Japan
KALISPEL II is offline   Reply With Quote
Old 04-05-2019, 02:47 PM   #3
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I never understood the "sucking the sediment from the bottom of the tank" arguement. It's not like the pump follows the fuel level and sucks from the top of the tank. Doesn't it always suck from the bottom of the tank?!?.....but I've been wrong before.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 04-05-2019, 06:04 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Running always low might be bad for the fuel pump.
Water sinks in the tank, so sucking up water from condensation in the tank is not a valid point, and sediments are filtered before going into the fuel line... I usually fill when it's around 1/4 or when I know I won't have enough range to do my business. Else, it gets down to E.
Sent from my CLT-L04 using Tapatalk
My Dyno Run japle Performance Modifications 11 04-10-2016 04:32 AM
TSNW 1st Annual Benefit Poker Run: Relay for Life, April 19th 2014 acrobatix Northwest 2 04-01-2014 11:09 PM
Mighty yaris dyno run! >:D Black_griffin6 Photo-Video-Media Gallery 0 01-02-2014 11:04 AM
Dealer(s) told me they needed to run my credit report even though I'm... firebird1999us New YARIS Purchase Forum 32 02-10-2009 10:08 PM
HIT AND RUN :( Pattycake Wash, Wax, Detailing, Exterior Repairs 16 12-26-2008 03:37 PM
