![]() Drives: Yaris hatchback 06 Join Date: Nov 2018
Diffrence front/back track width
Whats the mm diffrence? After a quick look with my stock winter wheel they have only a 1/4in diffrence tire/fender. But most people pit penguin spacer at 10 or 12/13mm...
I buy used wheel in 15x7 et25. I just install one in front and its flush to fender and i want the same for the rear What size spacer did you put |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Install the wheel on the back and measure from rim to fender. That will give you your desired spacer width.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
| May 20th Longwkend Monday Mosport DDT track event 10:30 - 5pm #5 Touge.ca event | Touge.ca | Canada | 0 | 05-08-2019 09:33 PM |
| October 8th Longwkend Monday Mosport DDT track event 10:30 - 5pm #24 Touge.ca event | Touge.ca | Canada | 0 | 10-04-2018 12:13 AM |
| May 22nd Longwkend Monday Mosport DDT track event 10:30 - 5pm #5 Touge.ca event | Touge.ca | Canada | 0 | 05-09-2017 01:37 AM |
| May 23-Victoria Longwkend Monday Mosport DDT track event 10:30-5pm #6 Touge.ca event! | Touge.ca | Canada | 0 | 05-05-2016 02:54 AM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
