Old 08-31-2019, 07:17 PM   #1
jayis
Drives: 2008 Toyota Yaris
Transmission Control Cable Clips
I am in the middle of replacing the clutch on my 2008 by following the repair manual (https://cardiagn.com/2007-toyota-yar...r-manuals-pdf/). Does anyone know how to remove the "transmission control cable clips"? The ones with washers are super easy, I'm talking about the other two. Below is a link to a video with me showing them, and attached is the part of the repair manual I am trying to complete.
https://www.youtube.com/watch?v=x_2CuZDy87Q
File Type: png Screenshot from 2019-08-31 19-02-20.png (94.3 KB, 37 views)
jayis is offline   Reply With Quote
Old 08-31-2019, 07:24 PM   #2
jayis
Closest thing I can find to someone removing these is the video below. I tried using a pry bar a little but it was smashing down on the cable and all the rubber parts around the cable so I didn't want to use much force.
https://www.youtube.com/watch?v=MA0mG8q8zvM
Oh also I am aware of https://www.toyotanation.com/threads...clutch.489689/. I have really been mixing the two resources (that post and the repair manual). But either way, these shift cables need to come off.
Old 08-31-2019, 07:43 PM   #3
B.B._07
Drives: 07 5dr
You just need to grab the metal clip with a pair of pliers and pull them up. Can reinstall them by lightly taping them back down with a hammer.
Old 09-01-2019, 06:20 PM   #4
jayis
This worked, just had to pull on it way harder than I thought I should be. I also tapped a flat head screwdriver in between them in between tugging on it. Thanks!
Old 09-03-2019, 02:14 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yup, those are a pain to remove, especially if you live somewhere that uses salt on the roads. Vice grips or a big pair of channel-locks work best for me.
DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation CTScott DIY / Maintenance / Service 172 10-27-2025 02:04 PM
Werid Noise When I throw it into Reverse LoudYar General Yaris / Vitz Discussion 12 10-26-2020 04:57 AM
Yaris Cruise Control Auto evarkey Performance Modifications 1 07-02-2014 07:56 AM
2009 Toyota Yaris OEM Cruise Control DIY BentSpace DIY / Maintenance / Service 7 04-16-2014 09:05 PM
