![]() Drives: 2006 Scion xA Join Date: Sep 2019
Starts the Dies
Hoping someone can help me out here. I bought a 2006 for my son to use as a commuter. It ran fine when we bought it. It needed the usual maint items, so I put it up on jack-stands and replaced a bunch of stuff, including new coils (Denso) and NGK plugs (.032). Now when I go to start it, it fires right up, idles for a second and then dies. It will do this repeatedly but never stays running. I confirmed the fuel pump is running. I went to the local pick-and-pull and replaced every fuse and relay under the hood and dash. Still the same result. Each time it throws all 4 coil codes. I'm baffled. One thought I had....To get it on jack stands, I had to lift one side at a time quite a bit. Does this car have a roll-over switch that might be shutting down the coils?
| Engine shutting off at idle, dash lights flickering, and engine starts on it's own! | jack.duno | DIY / Maintenance / Service | 0 | 09-23-2019 10:08 PM |
| Sometimes it starts and sometimes it doesn't | Roetroc | DIY / Maintenance / Service | 3 | 08-15-2019 07:11 AM |
| 2008 yaris starts then dies out in 10-15 seconds | Kmartboy808 | Hawaii | 4 | 12-24-2018 04:14 AM |
| Car Dies While Driving | josh044 | DIY / Maintenance / Service | 6 | 07-28-2017 11:07 PM |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 04:59 AM |
