Old 10-18-2019, 12:02 AM   #1
cesturdy
Drives: 2007 toyota yaris sedan
paint on threads of bumper arms and bumper brackets
my new bumper arms and brackets came painted black but there was scratches to the metal and metal could be seen at the seams/ welds. i grabbed a can of gloss black enamel and repainted these but realized the paint was running and that i got paint also on the threads. Will these be ok to install or should i do something to remove the paint on the threads?
cesturdy is offline   Reply With Quote
Old 10-18-2019, 09:26 AM   #2
Brighton
Knower of little
Drives: None
If you sprayed it on thick enough for the paint to run then clean the paint off the threads. You can try just treading a bolt in a couple times and spraying it off with brake clean/parts cleaner each time you remove it.
Brighton is offline   Reply With Quote
bumper bracket arms for vis rs bumper Innovative 1 Cosmetic Modifications (Exterior/Interior) 84 11-08-2017 04:17 PM
WTB: Front Bumper, Bumper Arms, Brackets and RH Radiator Arm n.a. Willing to Buy by private party 3 02-12-2012 01:14 PM
