Old 11-03-2019, 01:26 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Muffler replacement
A while back I bought a new muffier for Yaris. Amazon wharehouse deal $25 for a stainless walker . Plus $15 for donut gasket and fasteners .
Toolaholic is offline   Reply With Quote
Old 11-03-2019, 01:30 PM   #2
Toolaholic
Removing old muffler required long 14mm wrench and plenty of kroil penetrating oil.
File Type: jpg DFDA6C54-23AF-419B-9C13-B5598081EFC2.jpg (90.5 KB, 129 views)
Old 11-03-2019, 01:37 PM   #3
Toolaholic
Old muffler. Broke free with a Bergen long double box. Removed with SK G pro 14x15mm
File Type: jpg FA4E0F73-AFC0-4B31-9CEB-18DB4C460AD0.jpg (403.4 KB, 133 views)
Old 11-03-2019, 01:44 PM   #4
Toolaholic
Images of new muffler and hardware . Springs are to flex when going over bumps
File Type: jpg 41EBCDD5-AD09-44F2-84AA-8D244F64AB5C.jpg (120.8 KB, 130 views)
File Type: jpg F7B5342B-6E81-4EB7-9F5B-F670060D7D5C.jpg (129.3 KB, 131 views)
Old 11-03-2019, 01:46 PM   #5
Toolaholic
The rubber hangers muffler hooks go ion.
File Type: jpg BA681202-2E45-4946-8784-2C535FE26CD9.jpg (106.0 KB, 128 views)
Old 11-03-2019, 01:51 PM   #6
Toolaholic
View of walker muffler installed .view of joint
File Type: jpg BAD6FF80-3E77-47C3-8108-14E3F2FE2FC8.jpg (100.1 KB, 134 views)
File Type: jpg 8D54A025-A27D-4484-BFB7-836FF939A355.jpg (73.1 KB, 130 views)
Old 11-03-2019, 01:57 PM   #7
Toolaholic
It’s hard to break nuts free on old muffler and hard to get old muffler off exhaust hangers . I sprayed silikroil penetrating oil on rubber hangers to get the metal rods out of rubber grommet .
Old 11-03-2019, 02:06 PM   #8
Toolaholic
Test to see if exhaust gas/water leaks from joint at start up . After pipes get hot sometimes leak seals. If leak tighten some more. It’s hard to tighten with the springs on bolts. That’s why long double box wrench is used.
Old 11-03-2019, 02:12 PM   #9
Toolaholic
Muffler used : Walker 54743 Quiet-Flow Stainless Steel Muffler Assembly https://www.amazon.com/dp/B007EJMLKM..._C3zhyhoGF9ZLL
Old 11-03-2019, 02:14 PM   #10
Toolaholic
Hardware : Walker 36454 Exhaust Spring Bolt Kit https://www.amazon.com/dp/B002VVJRDM...p_mob_ap_share
Old 11-03-2019, 02:15 PM   #11
Toolaholic
Donut gasket : Walker 31387 Hardware Gasket https://www.amazon.com/dp/B0015KZM2K...p_mob_ap_share
Old 11-03-2019, 02:32 PM   #12
Toolaholic
Factory muffler had nut built into muffler . Bolt threaded into muffler . New walker needed a separate nut. I held built in nut with socket or wrench (can’t remember ) and used long double box wrench on bolt for removal. Installing I held nut and tightened bolt against spring.
Old 11-03-2019, 02:40 PM   #13
Not sure what you are trying to convey here. New gaskets need to get hot and melt slightly to completely seal the joint. Spring bolts purpose is to draw the flanges together as the gasket seats itself over time.
Old 11-03-2019, 02:44 PM   #14
Toolaholic
It was so hard to pry muffler off rubber mounts that I bought this for next time . OEMTOOLS 25543 Exhaust Donut Stretcher https://www.amazon.com/dp/B004FEJIW8..._b-XVDb6VQWTYS
Old 11-03-2019, 02:45 PM   #15
Toolaholic
That’s what happened it leaked slightly when cold but it did seal up nice later . Trying to convey if a nice amount of gas/water leaking out tighten it more.
Old 11-04-2019, 12:54 AM   #16
bairjo
I had the local shop replace my muffler with 2 different aftermarket mufflers. One was bouncing off the inside of the fenderd since it did not fit correctly The second one he tried just was not quiet. Drove me nuts! I ended up pulling it off my self and installed a genuine Toyota muffler. Now I am happy and learned a lesson regarding mufflers....did you learn anything me sharing this?
Old 11-04-2019, 07:58 AM   #17
Toolaholic
The walker has a different shape from OEM but fit quite nicely. One hanger wasn’t used. No problems whatsoever.. I don’t know what your muffler shop was using but walker is a reputable company .
Old 11-04-2019, 12:30 PM   #18
Leegamer
Leegamer's Avatar
How does it sound compared to stock?
I'm a hermit named Lee
Exhaust leaking after replacing rear muffler ThinkPad DIY / Maintenance / Service 13 08-20-2017 12:21 AM
rear muffler hanger broke BobTheYaris DIY / Maintenance / Service 2 09-21-2016 06:59 PM
Muffler fell off, pipe size? shepd DIY / Maintenance / Service 4 08-28-2016 10:01 PM
Bumper replacement mchamp00 DIY / Maintenance / Service 0 07-03-2015 11:45 PM
Need Help to change Muffler sobri46 DIY / Maintenance / Service 3 02-13-2014 01:42 AM
