Old 11-13-2019, 05:33 PM   #1
tsk94
Drives: 07 Yaris RS
Linear coilover springs with Bilstein B8s?
Does anyone know if it's possible to run a linear coilover spring (Swift, Hyperco, Eibach etc) with front Bilstein B8 struts? I'm struggling to find info on the stock springs to determine whether the upper and lower perch are the same diameter and could be used in a linear spring, and what size it is to determine the size of linear spring to get.
I'm sure someone has either looked into this or possibly done it before so any information would be helpful.
tsk94 is offline   Reply With Quote
Old 11-13-2019, 08:08 PM   #2
stidnam
Drives: Starlet
I have Bilstein B8s, and the spring perches are exactly the same as the factory shocks. I also can't see how you'd run coilover springs in place of factory ones. I'd suggest finding some factory springs and taking some measurements.
stidnam is offline   Reply With Quote
Old 11-13-2019, 08:19 PM   #3
I'm thinking he's just using bad terminology. Suspect he is really speaking coil springs, not coilover springs.
Old 11-13-2019, 08:23 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I'm running Tein S. Tech springs and about to install Bilstein B8's. Should work fine. I'm just looking for better bump stops and top mounts before installing.
On Instagram
On Wheelwell
Old 11-13-2019, 08:23 PM   #5
tsk94
Drives: 07 Yaris RS
Well, yes - I'm refering to coil springs. Linear rate springs are often categorized as coilover springs, as they are typically only used in a coilover application. See Swifts site for example: http://www.swiftsprings.com/
Old 11-13-2019, 08:25 PM   #6
tsk94
Drives: 07 Yaris RS
Yeah, I wasn't sure if it was possible. I'm planning to measure some stock ones to confirm in the future - just thought to ask here.
I know for Koni yellows for example, you can run linear springs with them on certain application. Figured maybe you could do the same with the B8's for the Yaris.
Old 11-13-2019, 08:30 PM   #7
tsk94
Drives: 07 Yaris RS
Aren't the Tein's a progressive spring? I've considered those, but I'm thinking I want something a bit stiffer.
Old 11-15-2019, 12:22 PM   #8
ern-diz
ern-diz's Avatar
They are a progressive spring. My hope with the B8's is that they stiffen things a little and last longer than OEM under lowering.
On Instagram
On Wheelwell
Old 11-20-2019, 08:05 PM   #9
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
How you all liking the B8s?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 11-20-2019, 09:16 PM   #10
myfirstyota
3 Yaris and counting..
They are much stiffer than stock amd are designed for lowering springs. I have them with tien stechs in my 07 2zr swapped car
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 11-21-2019, 11:20 AM   #11
ern-diz
ern-diz's Avatar
Nice. Did you go with OEM bump stops and cut them down, or did you find something a little better?
OEM top mounts, too?
On Instagram
On Wheelwell
Old 11-23-2019, 07:09 AM   #12
myfirstyota
Yes oem top mounts and I just cut the stock bump stops.
Old 11-25-2019, 04:10 PM   #13
ern-diz
ern-diz's Avatar
Thanks
On Instagram
On Wheelwell
Old 12-04-2019, 11:31 PM   #14
malibuguy
Obsessed with 1.5L
My tokico blues are pretty rough, especially in cold weather.
-96 Tercel 4dr
Bilstein B8's tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-01-2017 10:52 PM
Looking to upgrade my coilover springs TerenceCruz Willing to Buy by private party 14 01-30-2015 01:47 PM
Question about mixing progressive with linear springs YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-10-2013 01:01 AM
FS: Megan Coilover Springs 62.190.007 1.5 Items for Sale by private party 16 12-28-2012 03:23 PM
Progressive vs Linear Springs Pitt Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-11-2009 10:09 PM
