![]() Drives: Yaris HB 5dr Join Date: Jan 2021
Yaris HB RS 4 door 2010
Hi, i need help. The fuses are ok. The car battery is ok. The battery of the key fob is good. The lights flash once when the lock button is pressed, and flash twice when I press unlock. The door ajar indicator light turns on when a door is open and turns off when closed. But nothing lock or unlock, with the control unit button or with the key fob, no door lock or unlock. Look for what is the problem.
2ZR swap. DO IT! Ask how!
Sounds like it might be the 25A D/L fuse on the Main Body ECU block. Look under the dash panel by the OBD-II port. If the fuse is blown, that means there's a problem with one or more of the door lock actuators.
Thank you CrankyOldMan.
That was the 25amp fuse. I was probably in the rush when I first searched. Not easy upside down. |
Yes, those are tricky to get to. Glad I could help!
| Door lock issue - new key or lock? | RedSuns | General Yaris / Vitz Discussion | 17 | 11-01-2021 06:30 AM |
| Issue where dashlights either turn on or fade on when car off | razingman | DIY / Maintenance / Service | 0 | 01-17-2021 12:24 PM |
| Weird starting issue | shepd | DIY / Maintenance / Service | 7 | 03-22-2016 11:20 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 04:20 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
