Anybody use a dipstick oil sucker?
My brother is sending me a 12 V oil sucker that removes oil through the dipstick hole
Does anybody have any experience and advice on using one of those? ![]() Thanks!
I have but not on a yaris, it works well if you have a large diameter dipstick tube and the oil is hot. I'd like to tap a hole in the pan for a 3/8 tube, the lower oil pan is easy to remove.
Why not jack up the car and use the drain bolt? You are talking about motor oil, right, and not ATF? I have one of those pumps. It works great, but I basically use it for pumping oil into my rocker panels.
I have Parkinson’s and my brother thought this would be easier for me. There actually are cars you can change the oil filter without getting underneath. I don’t suppose I will use it on my Corolla but it would be great For my craftsman garden tractor which has a very complicated drain valve.
#6 | |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
