Rotors and Pads Replaced
Been meaning to do this for a while. I did it mainly for cosmetic reasons. Rotors had the usual rust scale on the vanes. The brakes were working fine, with a tiny bit of shaking while high speed braking (over 140 km/h). I know, I know but the car just wants to go fast.
Not my fault, the car's.I actually reused the OE (I think) pads, which were replaced not that long ago. They were perfectly smooth, with, I'd say, 80 - 90% lining remaining. The aftermarket ones were chamfered on the ends and don't seem to have as much contact surface. The job was uneventful with the exception of the upper driver's side caliper bracket bolt. That was a beeotch. The lower strut bolt makes it hard to use an impact gun. So, a 17mm wrench and BFH was used. Probably took 5 minutes of solid hammering to loosen that up. Needless to say, every bolt got a nice application of anti-seize, as did the hub/wheel contact surfaces. All four caliper pins operated smoothly but still got a cleaning and repack with silicone brake lube. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-02-2020 at 11:57 PM. |
| Time to replace rotors. Which brake upgrades? | BennyLava | DIY / Maintenance / Service | 25 | 05-16-2016 06:57 PM |
| New front brake pads and rotors | NEexpat | DIY / Maintenance / Service | 7 | 09-10-2013 11:43 AM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 05:43 PM |
| First thoughts: Carbotech XP8 pads and slotted rotors | jkuchta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 12-19-2008 11:21 AM |
| New Pads and Rotors after 18K Miles??? | dadi_oh | DIY / Maintenance / Service | 19 | 09-06-2007 09:52 AM |
