Alignment and a little exhaust work
Had the car in to a local shop for an alignment after my coilover install. For such a small town, this outfit has a really high tech Hunter alignment system. It was the first time I've actually seen an alignment done. Very interesting. I asked about the toe at the right rear and the tech said it's so minor that I shouldn't worry about it. I'm guessing if I want to bring it back in, I might need a shim or something since there's no adjustment at the back - at least that's my understanding. Open to the opinions of those familiar with the rear suspension. While I was there, I got all 4 tires balanced.
I also had them remove a clamp on my exhaust and weld the connection. It basically gained me about an extra 1" of clearance. I will likely be dropping the car a bit in the near future, so they know I might be back for a small camber and toe tweak. I was impressed when I was only charged $120.00 for all the work.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-30-2020 at 09:56 PM. |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I get the alignment shim disc and minimize that variance but thats me. You probably never feel that unless you drive hard
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Yeah, as shim at the RR will help put both of those readings closer to spec.
Thanks gentlemen! I will look into a shim to get the rear right wheel back within spec.
You have the read out, so you know (or can figure out) how to put the shim in. Watch some youtube videos on installing them. It'll save you some money by installing it yourself.
For sure. I assume shims are generic? Will investigate. Thanks!
The shim has to fit the wheel bearing mounting flange pattern.
| No factory rear alignment gear? | bad | DIY / Maintenance / Service | 6 | 01-28-2015 01:21 PM |
| Alignment Question | gsf1200m | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-16-2009 11:35 AM |
| WOW What a difference an alignment makes!! | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-12-2009 06:29 PM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 08:01 AM |
