Drives: Yaris automatic 2004 Join Date: Aug 2020
Rattling sound on Yaris when A/C is off
I own a toyota yaris 1.3 automatic. I have a weird rattle sound when idle and very noticeable when starting acceleration but only when the A/C is OFF. As soon as I turn A/C on, the rattling sound disappear.
Maybe something with the A/C? |
Most likely the a/c compressor clutch.
#3 | |
#4 | |
That horizontal tube can be moved back and forth in the little plastic retainers. Can you maybe indicated on a copy of your pic where the contact is? Nice clean engine bay, btw.
#5 | |
![]() As for the rust at the subframe, my advice would be to get some oil or some other thin oil-based substance in there soon. Rust Check "red" in cans would be perfect. I'd literally unload half a can in each side. It may drip out, so putting an old blanket or something under there might be a good idea. The oblong rubber plugs just outboard of those supports should access the inner cavity. When I am done welding, I plan to drill a hole at the lowest part and install a 1/2" plastic plug. That way I can access the area easily when I do my twice annual rustproofing. Addition: If you do take out those rubber oblong plugs, you might note that the area is filled with sand and debris. I took the equivalent of about a cup of sand and crap out of each side. This is the 'design flaw in this generation of car (hatch, not sure about the sedans). That stuff in there holds water like a sponge.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-31-2020 at 11:31 AM. |
#6 | |
Good to hear that your A/C noise is gone. I hate rattles, creaks, clunks and any other sounds that are not supposed to be there. Haha. Oh, and your car is in great shape back there, unlike many from the Maritimes. We seem to used an astronomical amount of road salt here. I think the DOT operates under the assumption that if they don't use all their salt in a year, they won't get budgeted as much the following year. I've seen them dumping salt on dry roads with no weather forecasted. End-of-rant.
#7 | |
I would prefer rock chips as they are on the outside and can be touched up. The salt is so insidious once it gets into the inner panels.
Konstantin88, please check out my Red Yaris restoration thread. I discovered how you can access the large inner cavity that is prone to rust.
Just sharing my experience with rattling sounds with AC engaged and idling.... It was the exhaust heat shield that rusted off and with specific engine revs (hot engine, AC on, idling) it got rhytm and started shaking like mad. I took it away completely and driving a few years since then.
I know that this is not the case for your OP but someone may find this thread later when searching for answers. |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| Help re my rattling Yaris! | lou3939 | DIY / Maintenance / Service | 2 | 03-11-2012 02:25 PM |
