Old 09-25-2020, 11:14 AM   #1
bronsin
bronsin's Avatar
Maintenance not in the owners manual
Battery corrosion. Some batteries corrode some don’t. It’s caused by battery acid gas leaking around the terminals. Whenever I get a car first thing I do is grease the terminals with wheel bearing grease. But you still have to check periodically unchecked you can have a real mess and a no start. If there is corrosion baking soda mixed in a pot of hot water and a wire brush will scrub it away. Then you can reapply the wheel bearing grease
Old 09-25-2020, 05:42 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yup. I've seen a lot of nasty looking battery terminals. Definitely should be part of the routine maintenance schedule.
Old 09-25-2020, 09:18 PM   #3
ex-x-fire
Fluid Film is good for the batt terminals.
Old 09-26-2020, 12:52 AM   #4
bronsin
bronsin's Avatar
What’s that?
Owner's / Service Manual tyrone_yaris General Yaris / Vitz Discussion 3 01-30-2012 01:02 AM
For Sale: 1993 Honda Civic Si 2dr Hatchback 5sp Manual Effizienz Cars for Sale by private party 9 01-17-2012 12:08 PM
Warranty Information for US Yaris Owners AdeJong 03 General Yaris / Vitz Discussion 4 09-19-2009 11:14 PM
Yaris 2002 - Owner's Manual abhinav_kr DIY / Maintenance / Service 0 08-20-2009 12:49 PM
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 08:24 AM
