![]() Drives: 2005 Yaris TS Turbo 1NZ-FTE Join Date: Mar 2021
2005 TS Yaris fuel pump?
Hi!
First post on this forum so hello to you all :) I have a 2005 Yaris TS Turbo. This is as far as I know the European version of the Vitz. ***might be wrong here as you see further down*** During the really cold winter here in Norway my fuel pump died. So I was wondering if anyone knows if it is the same fuel pump in a TS turbo as in a Vitz? I have tried searching for this but it is quite hard to figure out. The engine code for my car is 1NZ-FTE and for a Vitz it is 1NZ-FT. The E at the end might just be "Europe" but I don't really know. Does anyone know the difference between them, if any at all? Maybe even know what pump fits the TS turbo? Is the pump labelled so I can just take it out and search for it perhaps? Any tips is appreciated :) And just for fun - is it possible to fit a more powerful pump and get a benefit without more modifications to accommodate the increased fuel flow? Edit: Should probably add my diagnosis: -The car had been sitting for several months in 0 degree fahrenheit/-20 celsius weather. -The tank was 3 quarters full -Battery was completely dead -Hooked up another good battery -Car cranks strong but no sign of detonation -Can't hear hum of pump when turning on ignition, but can hear the relay click -Checked a spark plug and it was dry even after a lot of cranking After looking at pictures of the Vitz I'm not sure they are the same car at all - This is how mine looks ![]()
feed my pet
https://en.wikipedia.org/wiki/Toyota_Vitz
Read under XP10 Asia Market P2 Vitz RS. Your model should be the NCP13 for JDM. 1NZ-FE is the engine code. Yours have the additional T for Turbo. Might be best to remove your fuel pump and check the part number before you purchase a replacement: https://www.ebay.com/itm/Fuel-Pump-f...8AAOSwuwRYLeii Last edited by Fluxtasy; 03-10-2021 at 11:12 AM. |
Yaris Hybrid Limited 2015
Cant you find the part number here.
http://www.japan-parts.eu/
Thanks to both of you for your reply.
Found the part to be 23220p. Does anyone know where to find this part cheap? Or does a fuel pump alone really cost 300-450usd? Does anyone know if this car has a Fuel Pump Safety Pressure Switch? Or any Yaris for that matter? Last edited by TS Turbo; 03-07-2021 at 01:31 PM. |
#5 | |
feed my pet
that sounds awfully highI don't think there's a safety switch. Like all Yaris/Vitz, you need to remove the rear seat to access the fuel pump. |
![]() ![]() Drives: Yaris T sport TRD turbo Join Date: Aug 2017
Same pump as the regular T-Sport.
Also the enginecode is 1NZ-FE(T) Where the T stands for Turbo which was added later on, The rest of the engine is the same as regular 1nz-fe These ecu's are locked so fitting a bigger bump is useless
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
| will a prisus fuel pump work in a yaris | jens07yaris | DIY / Maintenance / Service | 9 | 08-12-2012 01:08 PM |
| dose the yaris LB have a fuel pump? | Moses | DIY / Maintenance / Service | 12 | 05-28-2010 08:40 AM |
