problem with cold air intake
last monday it rained all day.
i was going home from work and my car started to jerk.. at first i thought i let clutch too fast so i kept going. moment later, i knew something is wrong so i was turn back to where i work. i stopped to make a left turn, and my car died. it was still raining and i had to push my car to the side. thank god our car is light and electric power steering is awesome. i called roadside assistance and towed my car to the dealer. i hooked scanner but no code showed up. took out MAF sensor and found some water. my filter was soaked with water and when i took it out of my car water was dripping. got my car started after drying air filter and MAF sensor. glad MAF sensor is ok. i'm shocked and scared to drive in the rain. i dunno what to do now if i should put back stock intake system or just change air filter to the one that need to put oil. i've heard oiled filter they don't get soaked with water. btw i didn't go over any puddles.. i think it was just soaked from leaving my car outside in the rain. any suggestions? |
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
i'll go stock again, water in the cylinder is not good man
20 years... alive and kickin'!! ![]()
That blows! Oiled filters do repel water and cannot be soaked (because they are already soaked with oil) but they have their disadvantages too. (ie. Oil coating the MAF sensor) Do you have the AEM?
Ecurie Snoopy Lives
Yes I read in your garage you have the AEM. There should be some kinda protection against this problem. TRD has such a device for their CAI. I prefer the short RAM intake because I had fears this would happen, especially in the lower mainland. What did you dealer say about this?
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
![]() Drives: 3-dr MM liftback Join Date: Apr 2007
That seems odd.. I have the AEM and the way it's mounted it seems that there should be little chance of water soaking the unit or even the filter. Maybe you have an opening somewhere where water is being let in. My filter sits right behind the driver side fog light cover and as far as I checked i could not see any way for water to get in cause of the wheel cover and the plastic bottom thing-a-majigger cover that goes across the entire bottom of the car right underneath the bumper. .........hmmmmm...thinking it over again I just cant figure out how it would happen but please let us know cause I dont want to be caught in that situation.
this is my signature |
#6 | |
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
I have the TRD,never any problem,but heres a tip,when its raining,stay a good distance behind other cars if possible,and change lanes if your behind an 18 wheeler on the highway.18 wheelers create this mist of water behind them,its really light mist and can travel straigt to your intake,because your intake is like a vacum,and even more so at high speeds.Cars create this aswell.just not as bad.Hope this helps.
i just changed my filter to oiled one. problem solved.
i've been driving with oiled filter for month and half and it seems working fine. i could hear air sucking louder and got little more pull with my butt dyno. lol i think dry air filter isn't suitable with vancouver weather. rains too much.. |
#9 | |
Ecurie Snoopy Lives
Yes it rains pretty hard here in VAn. Not like it Cali where it's pretty dry alot of the time. One reason why I didnt go the CAI way or go with the scooped carbon fiber hood. Tooo much rain.
Well glad the problem was solved. Here in Los Angeles I guess i'll just keep in mind the tips about driving behind cars and 18 wheelers since it doesn't rain much or very hard. Later just to have peace of mind I'll invest in a bypas...but when fall rolls around in 6 months.
#11 | |
Ecurie Snoopy Lives
I think you have your running lights on so the air has to go around the bumper or through the radiator opening.
Should have purchased a TRD Cold air intake for your yaris. (PN: PTR03-52070) TRD cold air intake comes with a bypass valve in the upper pipe to prevent water from entering and reaching the MAF sensor.
i have the aem with no bypass and there is no problem.. and anyway you can buy the bypass valve for 40 $.. you just cut the pipe and install it ;p
#14 | |
Ecurie Snoopy Lives
#15 | |
toyota
adjustment..
did you have to adj your idle response as well i heard some that need to be done
#16 | |
toyota
soaked filter..
just found out that our yaris didnt have rubber blocking the water from comin in on the filter bay area its actually coming from the top of the headlight unit.. washed my car last week and open the hood after and found out my air filter boxed was soaked water all around it..hope it didnt go in the filter..although there is space there for it to come in..got to get rubber around it!!!! check it out people.. water getting thru!!!!!!!!!!!!!!!!
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: May 2007
paper filters and non-oilder filters suck and should never be used. OIled filters flow better, trap more crap and flow better. =) Just ask any sportbike owner.
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass! Many thanks to our sponsors: Weapon-R http://weapon-r.com Megan Racing http://www.meganracing.com Les Schwab Tires http://www.lesschwab.com 317 graphics http://www.317graphics.com |
![]() Drives: Yaris LB Join Date: Apr 2007
just got my lb a couple weeks ago. havent really looked at the engine bay, but if you have the aem cai the a bypass valve will prevent sucking up water. how hard was it raining anyways?
| Cold Air Intake | yariman | Performance Modifications | 21 | 10-03-2010 07:20 PM |
| Cold Air Intake vs. Short Ram Intake | nevermorez | Performance Modifications | 1 | 01-24-2007 04:25 PM |
| AEM Cold Air Intake!!! | BulletProofAuto | Sponsors Classifieds Area | 18 | 09-19-2006 09:33 PM |
| Cold Air Intake ? | pegcityrs | Performance Modifications | 47 | 04-17-2006 07:43 AM |
