Drives: 2010 Toyota yaris Join Date: Jun 2021
Parasitic draw/drain
Greetings,
First off this Toyota is my wife's car and im use to working on my older trucks (76 Cheyenne w/454 and 86 silverado w/379 diesel) that being said, im not really the best at electrical issues with newer stuff. Basic background of the issue and what lead me to here: The car had been running fine and then one night she forgets that she had her key in accessory, few hours later and the battery is dead. I go and jump start the car, let it run for 10 minutes or so and call it a day. In the morning the battery is dead again, had the battery tested and replaced since it was defective. But i still had a hunch this was bigger than just a battery issue, i tested the alternator output and it came to about 13.8-14 (alittle low i think) and then i tested for a parasitic draw. Thats where im alittle fuzzy, dc current doesnt really change that much from vehicle to vehicle so i did this test the same way i always do it. Pop the negative lead off the terminal and hook up the multimeter to each end of the negative side, when i do that it reads 11.8-12.1 volts. So correct me if im wrong but this is not how the yaris should read. To try and find the issue or location without wire chasing, i test the tops of the fuses and see what they say (with battery installed). Everything was pretty low except the abs1/vsc1 fuse. I pulled it out to check the posts and it was reading 12ish volts. The part that confuses me is with that fuse pulled and then i do the draw test again i still get the same reading as before. So im not sure if its an issue prior to the fuse box or what any help would be appreciated 🤙
| Tags |
| drain, electrically challenged, parasitic draw, toyota, yaris |
| I have parasitic draw in D/L No. 1 Fuse 25A | Farman | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 02-01-2021 05:53 PM |
| Question on Parasitic Draw | rayfloyd170 | Third Gen Yaris General Discussion | 2 | 01-09-2020 01:03 AM |
| Parasitic draw kills battery | BennyLava | DIY / Maintenance / Service | 7 | 12-23-2015 07:36 AM |
| help! parasitic drain from the fuse labeled "ECU B" | rob_salsa | DIY / Maintenance / Service | 4 | 02-23-2012 02:28 PM |
