![]() ![]() Drives: Toyota Join Date: Jun 2011
2017 iA window stuck
My '17 Yaris iA is having a problem with the back passenger window. It will roll down but not up. I tested (with a voltage meter) voltage at the plug and get 12v on the grey wire and brown wire. The window motor I have will spin both directions. I used jumper wires between the plug and motor. The grey wire has voltage both up & down direction. The brown wire only has voltage going up. I tested continuity from the up/down switch plug to the window motor plug. Both wires tested good. The switch itself also tested good for continuity when checking for proper direction of flow.
Some I know suggested that I test the driver switch for everything too. I'm asking you all if there is anything else I should be checking? Thanks. |
| DIY - OEM Power Window Conversion | CTScott | DIY / Maintenance / Service | 29 | 10-27-2024 11:02 PM |
| Passenger Power Window replacement | AMOKS | DIY / Maintenance / Service | 0 | 03-15-2016 09:29 PM |
| Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 10:03 AM |
| Electronic Window Closer mod | cali yaris | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 11-11-2011 11:16 AM |
| Window won't work after changing speakers | Grantstead | DIY / Maintenance / Service | 0 | 07-16-2011 12:57 PM |
