Old 08-31-2014, 06:11 AM   #1
rasyaya
Drives: Yaris 2
Question Boost pressure values on Yaris 1.4L D4D 90
Hi everybody,
I have a 2009 Yaris with the 1NDTV turbo diesel engine (1.4L D4D 90hp).
I would like to have some information about boost pressure standard values.
A boost pressure vs rpm curve would be great, but even an info about the standard maximum boost pressure would be helpful.
P.S : the engine has a Variable Geometry Turbocharger, so no wastegate.
Thanks for your help
rasyaya is offline   Reply With Quote
Old 09-29-2014, 08:48 AM   #2
rasyaya
Drives: Yaris 2
Unhappy no one can help?
Bump
Old 09-29-2014, 10:06 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Not sure anyone knows. PM CTScott, he might have an idea, or maybe an idea where you could acquire that info.
Colin Chapman disciple
Old 09-29-2014, 10:47 AM   #4
I have never seen a chart, but according to the service manual the max boost at 5100-5250 RPM should be 2.2 to 6.5 psi.
Old 10-04-2014, 06:51 PM   #5
rasyaya
Drives: Yaris 2
Thumbs up
Thanks CTScott
So that is a maximum boost up to 6.5 PSI above atmospheric pressure I suppose.
I have the service manual for the petrol Yaris 2. Where can I found/download the diesel service manual?
Old 10-04-2014, 07:27 PM   #6
Originally Posted by rasyaya View Post
Thanks CTScott
Correct. I will send you what I have for the diesel.
Old 10-05-2014, 05:54 AM   #7
rasyaya
Drives: Yaris 2
Thank you very much for the link CTScott.
Old 12-21-2014, 06:49 AM   #8
DieselJuan
Drives: 1.4 D 90 BHP MT6
I also enjoy a diese 90 bhp. I am planning some mods to achieve better cooling and performance but I only have the petrol manual. Can you send me the diesel one, please?
DieselJuan is offline   Reply With Quote
Old 03-25-2015, 07:43 AM   #9
Giupo
Drives: Yaris
1NDTV from 2009 boost peak 0.85bar and costant boost 0.7bar, to increase the boost you have to remap the ECU.
I remapped the Ecu and now I have boost peak 1.1bar and costant boost 0.9bar for 110hp ;)
Giupo is offline   Reply With Quote
Old 05-03-2015, 07:21 AM   #10
Ludo
Drives: 2006 Hatch 1.4 D4-D
I have to kind of agree with Giupo, i can't remember stock boost on my 06 D4D.
But after i mounted a power box on the common rail sensor boost where about 0,9-1,1 bar.
For some time I had a power box on the MAP sensor, boost where 1,4-1,5 bar (peak boost 2 bar++) stock sensor is "blind" over 2 bar. Stock ECU reduces diesel pressure if boost is 1,5 bar.
I think stock turbo is good for about 140-150 hp max. I've mounted a bigger VNT turbo, bigger ic, portet top and bigger trottle valve, and aiming for 180 hp.
Ludo is offline   Reply With Quote
Old 01-16-2022, 02:21 PM   #11
oshimada
Drives: 2009 yaris xp90 1.4 Diesel
hello CTScott can you send me those too?
oshimada is offline   Reply With Quote
Tags
boost, d4d, diesel, pressure, turbo
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
Yaris d4d flashing hazards help!! djmix DIY / Maintenance / Service 0 06-08-2014 07:18 PM
yaris d4d Kiddi J General Yaris / Vitz Discussion 11 04-21-2006 03:17 PM
