Old 08-01-2021, 02:20 PM   #1
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Arrow 'Bolt in' lift kit for sale Toronto
A sad day has arrived. Ive decided to make more room in my driveway for new toys. As a result, ive scrapped the lifted yaris. She was well traveled with over 430,000 km.
Over 100,000 of those kilometers were with my custom made bolt in lift kit installed and happy to report there were no issues with reliability during that time.
The kit contains everything you'll need for a 3.75" lift in the front and approximately 4" in the rear. Im also including the 215/75/15 bf goodrich all terrain ko2 tires. 2 are worn about half way and 2 have a lot of meat left (I was lazy with my rotations). The only things you may need are some sort of mud flaps or fender flares pending laws in your jurisdiction and possibly extended wheel studs should you choose to use wheel spacers. Arp makes the extended studs for the lexus is 300, are available on Amazon and are a direct fit.
The kit can be installed with basic hand tools and a small grinder such as a dremel or die grinder. However, the front half of the kit is a pretty indepth install and requires partial removal of the front subframe. The rear takes about an hour to install.
The kit utilizes oem springs and shocks for ease of maintenance.
The kit contains:
• 6 front sub frame spacers and required hardware
• 2 front strut extensions including required hardware
• 1 engine mount spacer and required hardware
• 1 transmission spacer and required hardware
• 1 extended steering shaft + shaft boot
• 2 rear spring perch extensions with shock mounting provisions and required hardware
• 4 2" wheel spacers
• 4 bf goodrich ko2 all terrain tires in 215/75/15
• 1 modified downpipe including catalytic converter, o2 sensor and midpipe.
Disclaimers:
*Wheel spacers or rims with more offset are required to clear front strut extensions. Wheel spacers are included with the kit*
*Clearance to the body of the car may be required to fit included tires*
*Clearance to the firewall will be required for the revised steering shaft angle*
*Rims pictured are not included in the kit*
*I am not a certified welder*
*When installed, your Yaris will draw A LOT of attention. Be prepared to be stopped by random people to talk about your car and to be recorded while cruising the hiways*
There is over 6" of lift if using the included tires
Im not willing to ship the kit due to weight and size of the included tires, however we may be able to work something out in Southern Ontario as I'm always on the move.
The build thread can be found in my signature below
Asking price is $600cad
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 08-17-2021, 09:14 PM   #2
myfirstyota
Make me an offer... too many parts in my shed, too many tires in my yard
Old 09-30-2021, 09:44 AM   #3
myfirstyota
Sold pending pick up
Old 10-18-2021, 05:56 PM   #4
myfirstyota
Back for sale
Old 11-28-2021, 08:53 PM   #5
CincyC6
Drives: 2008 / 2011 / 2012 Yaris
Do you still have this?
CincyC6 is offline   Reply With Quote
Old 11-29-2021, 08:30 PM   #6
sh0rtlife
still got it?..willing to ship it WITHOUT the tires?
Old 01-10-2022, 03:40 AM   #7
Lanez
Drives: 2005 yaris
Can i buy this minus the tires? I live in vancouver but will cover shipping and pay the full price just dont wanna pay the shipping for the tires just craigslist em
Lanez is offline   Reply With Quote
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 04:59 PM
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 02:42 AM
FS: New Enon HID Kit H4 6500k in Toronto Mond'z Canada 0 05-09-2007 08:16 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 03:13 PM
