Old 09-06-2022, 10:53 AM   #1
k98shooter
Drives: 2012 Yaris Hatchback 3 door
Erratic shifting from 3rd to 4th
Son's car. 2012 Yaris hatchback automatic with just over 60k miles. The car ran silky smooth until now... No CEL, no stored error codes.
This happens after engine warms up to operating temperature. When driving at 20-40 mph, at a steady speed, without accelerating, the transmission starts shifting randomly from 3rd to 4th. Appears randomly fluctuating between 3rd and 4th. Often it shifts to 4th prematurely, so there is a sensation of power loss as the RPM is still too low for 4th gear. The car runs just fine at highway speeds and shifts through gears just fine when accelerating hard. He took the car to Toyota dealer who said it appears transmission issue, but could not give more specific answer (even though he paid $150 for "diagnosis").
Your input is highly appreciated. I suspect on of the solenoid valves, just not sure which one. Perhaps best solution would be just to replace entire valve body?
k98shooter is offline   Reply With Quote
Old 09-06-2022, 11:42 AM   #2
bronsin
bronsin's Avatar
Car was in some sort of accident recently, right?
Old 09-06-2022, 12:05 PM   #3
k98shooter
No, that was a different car. This one was never in an accident.
Old 09-06-2022, 01:13 PM   #4
bronsin
bronsin's Avatar
What is the condition of the transmission oil? Is it clear red or is it black/dark brown?
I would consider dropping the automatic transmission oil pan and examining it for cleanliness IE Metal shavings and other unpleasant things.
Old 09-06-2022, 01:49 PM   #5
k98shooter
It looks more red than brown. There was some super fine black power accumulation on magnets on fluid pan.
https://imgur.com/a/DGvbYu0
Old 09-06-2022, 01:49 PM   #6
k98shooter
Old 09-06-2022, 02:14 PM   #7
bronsin
bronsin's Avatar
Sounds pretty normal and there’s not many miles on the car. Nothing catastrophic anyway.
You’re you could always go to AAMCO and have them give an opinion.
Old 09-06-2022, 03:46 PM   #8
sh0rtlife
its the year of the trransmission failures
buddys honda gave up, bought a used car..its didnt make it home...trans...wnet hunting for other rigs that he would be happy with....adds full of the right rigs all with trans issues...widened the search..TONS of trans issues
yours sounds more like a electrical issue than a mechanical one tho
Old 09-07-2022, 06:01 PM   #9
xdarkxfirex
Drives: 2015 yaris le
Try using some Lucas. It might help.
xdarkxfirex is offline   Reply With Quote
Old 09-17-2022, 04:58 PM   #10
k98shooter
Replacement valve body fixed the problem. I don't know which solenoid was faulty, as the replacement VB came with solenoids.
Old 09-17-2022, 06:10 PM   #11
bronsin
bronsin's Avatar
Good work. Interesting there was no code thrown
2007 Yaris manual trans shifting from 2nd to 3rd not smooth gnx547 General Yaris / Vitz Discussion 6 07-30-2022 10:15 AM
3rd 4th & 5th gear rattle fishlurcher DIY / Maintenance / Service 3 07-30-2015 09:40 AM
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 09:16 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 09:16 PM
yaris jerks a bit when shifting to 3rd gear. abdallah380 DIY / Maintenance / Service 3 09-19-2009 04:45 PM
