![]() Drives: Toyota Vitz RS Join Date: Sep 2022
Unknown oil leak under manifold - need advice
Hello everyone,
I recently found a slow oil leak coming from under the manifold building up in the corner on my 2011 Toyota Vitz RS. Unsure if its the cover on the side or the main cylinder head seal that is leaking. Car drives very normal and the oil level hasn't not moved at all. Any help would be much appreciated ! IMG_0892.jpg |
Average KKT User
Drives: 2001 Echo Join Date: May 2020
This looks like a 1nz-fe so just from what I see it looks like its leaking from the timing cover there are oil returns to the pan on that side which are sealed via the head gasket Shown in blue (pic #1) but from what I see it doesn't seem like that is the problem. Looks like it is leaking from the timing cover right where the head sits on the block shown in red (pic #2 and #3). If anyone else would like to add there .02 please do!
PIC #1 PIC #2 PIC #3
If it doesn’t affect the oil level why worry about it? How much would it cost to fix? $$$?
Just my two cents!
Thanks for the information! I would guess going off this the timing cover seal is failing in that area?
Yes the oil level seems normal but still it is concerning to see a oil leak coming from this area of the engine bronsin |
There are several threads going back well over a decade of what I believe to be either similar if not the same oil weeping issue. After lots of discussion and debates, nobody had ever bothered to address it. It's just not a leak of magnitude to warrant tearing things down.
#6 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
dude, just clean it off with brake cleaner and call it a day, unless you want to spend an entire day tearing apart the whole front of the engine to address a tiny seepage. i guarntee you would not see that again for a long time if you just clean off with brake clean and move on
| Motor oil resource for performance engines | tmontague | Performance Modifications | 9 | 04-21-2019 11:46 PM |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 09:43 PM |
| JB Weld stock intake manifold port w/ 1ZZ Throttle Body | tmontague | Performance Modifications | 2 | 10-07-2015 10:31 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
