Old 11-04-2008, 10:53 AM   #1
Yaris Dyno charts
If you've taken your Yaris on a Dyno, post the results here, along with a list of relevant mods
To start off, here's one by staticorex, bone stock.
Old 11-04-2008, 12:35 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
kool cant wait to see the results
Yoda is offline   Reply With Quote
Old 11-04-2008, 10:24 PM   #3
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Was it a manual or AT?
Old 11-05-2008, 06:49 PM   #4
From a magazine, s/c Yaris:
http://www.turbomagazine.com/tech/07...fications.html
Old 11-05-2008, 08:49 PM   #5
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
5400-6100 not much difference in power output lol
Masteraal is offline   Reply With Quote
Old 11-06-2008, 12:57 AM   #6
Here is mine with intake, header, pulleys and axle-back exhaust:
Old 11-06-2008, 12:58 AM   #7
And here is mine with the turbo set up on stock motor @ 8psi,
along with a different pull from the dyno session shown before:
Old 11-06-2008, 06:00 AM   #8
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Here's mine:
DC Header, Fujitsubo Exhaust, Denso Iridium Spark Plugs, 5W40 Shell Helix Oil. Otherwise everything is as standard factory delivered.
Numbers on the chart are at the crank. WHP is roughly 102.75 and torque is 130Nm (95.8ft/lb).
EDIT: Thanks for pointing out the unit difference for torque; I have added the lb/ft conversion.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 11-06-2008, 09:29 AM   #9
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
that's because yours is measured in Nm :P everyone else is ft-lbs.
not a yaris but same engine anyways, only mods are intake and muffler replaced with a small resonator.
edit: manual transmission, did all runs in 4th gear
taKuto is offline   Reply With Quote
Old 11-06-2008, 01:44 PM   #10
Yoda
Yoda's Avatar
this will be a very useful thread
+1
Old 11-06-2008, 02:21 PM   #11
cleong, you're hp and torque don't cross at 5250 -- sup with that?
also, wouldn't the rev limiter kick in at 6250?
Or do you not have the same limit as we do in USDM?
Old 11-06-2008, 06:12 PM   #12
at3GG
at3GG's Avatar
Drives: 07 metmet LB
Is it all dynos charts that should cross at 5250...or is that just a correct setup for our engines?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 11-06-2008, 06:51 PM   #13
cleong
cleong's Avatar
I posted this chart before the Big Crash and someone explained its because the scale between HP and torque is different.
Your NA dyno chart seems to go to 6500rpm too. But redline's 6500rpm on my dashboard, I think. I'll need to run out and check it later.
TRD Blue brake pads
DC Sports header
Old 11-07-2008, 02:10 AM   #14
LtNoogie
LtNoogie's Avatar
Had to straight-line interpolate where the sensor had a bad connection.
Not as good as I had hoped. This was my baseline before the supercharger install.
Old 11-13-2008, 09:59 PM   #15
richardholdener
Drives: 2008 Yaris hatch
HP and tq are alwasy equal at 5252 rpm. The reaosn they don't cross on the graph is that the two scales are different. If both HP and NM (converted to tq) scales went from 0-160, then they would cross at 5252. Here is the 120-hp graph supplied previously before the hack. Mods were custom intake manifold, CAI, Xd tb, synthetic oil and off-road down pipe with no exhaust.
richardholdener is offline   Reply With Quote
Old 11-13-2008, 10:19 PM   #16
Treyz
~ ambient one ~
Treyz's Avatar
Now are these all with manual transmissions?
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 11-13-2008, 10:24 PM   #17
I would think so yeah... I have seen local dynos of stock AT's here doing about 80whp only...
Old 11-13-2008, 10:40 PM   #18
Treyz
~ ambient one ~
Treyz's Avatar
Yeah .. I got the Yaris purposely as a daily driver since I had my 240SX track/weekend driver so bought it in an atomatic.
Man am I kicking myself in the ass now after I got rid of the NIssan and started modifying the Yaris.
AMBIENTLIFESTYLE
Micro Image
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
