Old 12-20-2022, 11:15 AM   #1
IftyH
Drives: Yaris Icon Tech
Front Suspension Front Ball Joints Sweating!
Hi Everyone,
I’m new on this forum. I wish to pick your brains.
My 2017 Yaris Icon Tech (80,500 miles) is making crunching noises whenever I go over an uneven part of the road and humps. My local Toyota dealer in Watford said, “The front ball joints are sweating”. The repair bill is £1131.67.
Shouldn’t this be covered under warranty given that every service from new (9 services) have been carried out by them? They’re saying it’s wear & tear.
Please let me know your thoughts.
Regards.
IftyH
IftyH is offline   Reply With Quote
Old 12-20-2022, 02:03 PM   #2
bronsin
bronsin's Avatar
In The US Toyota warranty is 36,000 miles or 36 months which ever comes first.
So based on that your car would be out of warranty.
Old 12-20-2022, 02:54 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
What? Sweaty balls?
https://youtu.be/bPpcfH_HHH8
Old 12-20-2022, 03:50 PM   #4
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by IftyH View Post
Hi Everyone,
Regards.
IftyH
Just means balls joints are leaking. Might want to have a look yourself to confirm they are leaking grease.
If they are you can replace them yourself fairly easily or you can buy an entire new control arm with ball joint and new bushings while there for not that much more money aftermarket.
Compeer is offline   Reply With Quote
Old 12-20-2022, 10:41 PM   #5
ltwargssf
Drives: yaris
That's a bit ridiculous but that's probably the dealer quoting you for two entire control arms since toyota doesn't sell the balljoints separately and they wouldn't just do one side.
Balljoints are cheap for these cars and very easy to press in and out (50$ + you can go rent out a balljoint press for free at a parts store)
Independent shop shouldn't charge you over 200$ to replace one of them. For a 2017 car with under 100k, your control arms probably still have a lot of life in them so long as the bushings aren't cracked
ltwargssf is offline   Reply With Quote
Old 12-27-2022, 12:56 AM   #6
IndestructibleYaris
Shouldn't be covered under warranty. You've gone more than 3 times around earth if you'd have traveled in a straight line
IndestructibleYaris is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Front and Rear Suspension nisyota Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-27-2009 01:41 AM
Front end suspension making "Creaking Door"noise! Need help! Syroyizhka Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-03-2009 07:55 AM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 01:00 PM
