Old 11-08-2022, 07:05 AM   #1
Doobiejack
Drives: 2018 Yaris Hatchback
Low growl
My 2018 Yaris Liftback has developed a low growl I hear the most between 40 and 60 mph. I replaced all four tires which did not fix the problem. I think it may be coming from the rear of the car. Anyone have the same issue? The car has 50,000 miles on it.
Doobiejack is offline   Reply With Quote
Old 11-10-2022, 02:10 PM   #2
bronsin
bronsin's Avatar
Sounds like a wheel bearing to me. Jack up each wheel intern and grab it at three and 9 o’clock and try and rocket back-and-forth. Then try at 12 o’clock and 6 o’clock. Start with the rear wheels because that’s where you hear the noise.
Good luck and tell us what happens!
Old 11-10-2022, 02:12 PM   #3
bronsin
bronsin's Avatar
Hard to believe it’s a wheel bearing on that newer car but my Ford truck had a bad wheel bearing and 50,000 miles too
Old 11-10-2022, 05:13 PM   #4
I just replaced a rear hub last week. Lots of free play doing the wiggle test and all it did was humm. A bearing in bad enough shape to growl I'd imagine would be exhibiting more issues than just noise. I really don't believe bearing at fault, but you do still need to wiggle test them just to be sure.
Old 12-31-2022, 08:07 AM   #5
Doobiejack
Independent garage said the growl needs to get worse before they can figure out what it is. The local Toyota dealer did a "safety inspection" for $150 and gave me a quote of $2,000 to replace wheel bearings (HUB & BRG assembly). Quoted five hours of labor. I did not get it done.
Old 12-31-2022, 03:18 PM   #6
sh0rtlife
LOL 5 hours labor is a joke..you can do it in your driveway with a jack faster than that
Tags
2018 yaris growl
