Old 06-10-2018, 08:22 PM   #1
usmanimtiaz
Drives: yaris 2008
yaris 2008 loses power on slow speed with ac
I've toyota vitz 2008 automatic, Recently my car loses power on slow speed with ac on and it vibrates a lot before shutting engine off . I've replaced injectors, plugs and installed a new battery but the problem is still there. yesterday my mechanic said this could be because of bad transmission fluid so I asked him to change the transmission oil but it was insane the problem just won;t go he finally gave up on my car by saying the only thing left is throttle body which im not sure about because there's not fault code in the ecu about it and if we replace it im not sure if it will solve the problem. (since int's an expensive part and I can not return it )
Im looking for suggestions if anyone has ever experienced this problem before, is it a bad throttle body? should i go ahead and replace it?
usmanimtiaz is offline   Reply With Quote
Old 06-11-2018, 01:48 AM   #2
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Possibly your ac compressor is on the way out, at high speed your engine is able to compensate for the drag its causing but at low speed it's too much, causing your engine to stall. If you switch your ac off does your car run fine?
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 06-11-2018, 12:12 PM   #3
usmanimtiaz
Drives: yaris 2008
I recently changed my ac compressor about a month ago so compressor is fine,
without ac engine does not stall but i can feel the rmp drop.
Old 06-11-2018, 12:22 PM   #4
usmanimtiaz
Drives: yaris 2008
if i put my car in parking and then switch on ac it works fine. this problem occurs in Drive
Old 06-11-2018, 04:35 PM   #5
castles
Drives: 2008 Yaris
I had loss of power and low idle to the point of the car dying. It was a bad coil pack. CEL would flicker but not stay on. AutoZone was able to get codes using a CAN compliant obd reader. It was random, had nothing to do with AC, in my case.
castles is offline   Reply With Quote
Old 06-11-2018, 06:56 PM   #6
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
which vitz the sedan or the hatchback.
DarkShadowFox is offline   Reply With Quote
Old 06-11-2018, 07:32 PM   #7
RicStyx
On the topic of the throttle body, I would not replace it but rather clean it with throttle body cleaner, if its dirty it can cause idle issues and stalling in some cases.
Old 06-12-2018, 04:30 PM   #8
usmanimtiaz
Drives: yaris 2008
yaris (hatchback)
Old 04-15-2023, 04:37 AM   #9
adeking
Drives: Toyota Yaris
Greetings from this side, I'm experiencing the same issue on my yaris sedan same year, would really appreciate knowing how this was resolved. Thanks
adeking is offline   Reply With Quote
Tags
idle problem, yaris 2008
Installing power locks in 2008 Yaris Hatchback mills DIY / Maintenance / Service 4 05-24-2011 01:43 PM
***** GREAT DEAL *** 2008 Toyota Yaris Sport 2008er Cars for Sale by private party 2 04-22-2009 08:25 AM
