Old 02-15-2017, 05:39 PM   #1
esse10
Drives: 2009 yaris 2 door
A/C condenser
Anybody know if there is a DIY on replacing the A/C condenser? or past experience doing that repair.
esse10 is offline   Reply With Quote
Old 03-01-2017, 12:09 PM   #2
esse10
A/C
Seems like not too many A/C mechanics around here or knowledgeable folks
on the A/C system.
Old 03-01-2017, 12:26 PM   #3
tmontague
tmontague's Avatar
if you remove the front bumper you'll notice a cross bar above the radiator/condenser. This bar is held down by 4 bolts (2 on each side). Remove those bolts and lift the cross bar out. Once you disconnect any hoses and fitting attached to the rad and condenser you can then just lift the rad/condenser assembly out as it just sits on rubber dampeners.
The rad and condenser are just connected with clips. Unclip those and they should separate. Do the opposite to re install then pull a vacuum on your a/c system to make sure there are no leaks. Then add 1/4 ounce of uv dye and re charge your ac with just over 12 ounces of r134a.
It's not a big job and once you remove the bumper you'll see what I mean about the cross bar. The hood latch is held onto it with 3 10mm bolts so you'll have to remove that as well.
Old 03-02-2017, 11:59 PM   #4
B.B._07
Drives: 07 5dr
Here's the procedure from the factory service manual.
Old 03-30-2023, 07:13 PM   #5
esse10
A/C
I know that this is an old posting but if you're still out there thanks for the information. it's exactly what i was looking for , torqu values and oil type & how much.
Help: A/C Questions flamingchicken4 DIY / Maintenance / Service 11 12-29-2018 01:53 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
Larger condenser for stock A/C? rningonfumes DIY / Maintenance / Service 3 07-25-2016 10:43 PM
Replaced my A/C condenser villdemar DIY / Maintenance / Service 5 05-28-2016 03:13 PM
Just replaced my A/C condenser, now what? Astroman DIY / Maintenance / Service 5 04-02-2014 06:26 PM
